IGN 1 wire from ignition switch melted
#1627657
06/02/14 12:32 PM
06/02/14 12:32 PM
Posts: 582 PA
BTTG
PA
Could a short of the IGN 1 wire at the ignition switch end (the 16 gauge dark blue wire w/ white tracer that runs from the ignition switch to the ignition side of the voltage regulator underhood) have caused my water temp and fuel gauge to have burned out? The first few inches of my IGN1 wire had the insulation melted off. there is another blue wire (18 gauge) at this end that is ganged together at this connection on the ignition switch that runs up to the instrument cluster... this sounds linked to me.
If this is the case I need/want to figure out whey the IGN1 wire failed. Could accidentally grounding one of the coil leads for a few seconds have caused the IGN 1 wire to melt at the ignition switch? Everything else that is relatively inspectable seems fine. I took the instrument cluster out and have examined parts of the underhood harness, but have limited access... I cut into the harness tape and the melted IGN 1 wire appears for the first few inches (ignition switch end) then as it goes towards the bulkhead it is no longer melted (can't gain access all the way to the bulkhead though... engine side is all good)
Thanks in advance
Re: IGN 1 wire from ignition switch melted
[Re: JohnRR]
#1627659
06/02/14 01:56 PM
06/02/14 01:56 PM
Posts: 5,165 CT
GTX MATT
CT
I melted that wire a few years ago. No one could tell me why. I couldn't find a reason. When it happened my ammeter was going from an extreme charge to an extreme discharge rapidly, and it would only do it accelerating under a load. The only reasons I could think it melted was that I had hooked my coil directly to the ballast resistor, the had recently installed a Mopar Performance blue voltage regulator, and/or my field wire on my alternator had a crack and shorted against something.
I changed my engine wiring harness and repaired the dash harness. I changed the alternator too. I also went back to a regular style voltage regulator and wired the choke differently.
A few weeks later the battery developed a dead short.
[Re: JohnRR]
#1627660
06/02/14 02:25 PM
06/02/14 02:25 PM
Posts: 582 PA
BTTG
PA
maybe it was the +... it was an error so now thinking back I can't remember for sure ex except that I forgot to put 1 of the wires back on the coil and it grounded to the engine... i am running a pertronix under cap module.
