glass hood question. #1627421
06/01/14 09:28 PM
06/01/14 09:28 PM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
I picked up a flat 'glass hood for my '71 Dart. It's not designed to use the hood hinges, just dzus fasteners. Can anyone tell me what kind of project its going to be to remove the old hood hinges? I don't want to get into a big project right now. Does anyone know how much lighter this new hood is then stock? Or what a stock hood weighs? I can go weigh mine on a scale.
Re: glass hood question. [Re: 80arrow] #1627422
06/01/14 09:38 PM
06/01/14 09:38 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
are you taking about a stock steel hood if so they are HEAVY compared to a glass hood and are you wanting to remove the hinges from the old hood or body of the car
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: glass hood question. [Re: 67mprfan] #1627423
06/01/14 09:58 PM
06/01/14 09:58 PM
8
80arrow Offline OP
80arrow  Offline OP
Yup talking about taking the stock steel hood off and taking the hinges off the car completely.
Re: glass hood question. [Re: 80arrow] #1627424
06/01/14 11:01 PM
06/01/14 11:01 PM
Unbolt the hood from the hinges to remove the hood, remove the front fenders to remove the stock hood hinges from the body I removed the stock hood springs from my Duster(I left the hinges on the car ) and had some aluminmum T stock bonded onto the hood underside so I could still use the stock hood hinges with no springs so I didn't have to remove the hood every time I wanted to look or work on the engine I did use 8 Dzuz fasteners also to hold the hood on Four on the front, one on each side in the middle and two between the stock hinges in the rear and in the middle of the hood, it was a fibreglas race hood with a SS 1968 hemi race scoop molded onto it during the making of it I used to race in SO CA at LACR, the wind was always blowing there and I saw more than one lift off hood get blown across the pits by a new racer coming there I have also lost a race hood when I forgot to put all the hood pins back on when I was in a rush IHTHs
Re: glass hood question. [Re: 80arrow] #1627425
06/01/14 11:10 PM
06/01/14 11:10 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I think you can remove the hinges by going thru the fender shields.I have a 'glass hood on my 71 Demon,and I like it.it's nice to not have the hood on when working on the car.
Nautilus Racing-
Re: glass hood question. [Re: Chris2581] #1627426
06/02/14 12:15 AM
06/02/14 12:15 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We just did that on my sons 72 Dart as he is going to go with a glass hood. We took the doors of one at a time as it made it so much easier. Just mark the doors and put them right back on in the same posistion. It made the job much easier. Ron
Re: glass hood question. [Re: 80arrow] #1627427
06/02/14 03:34 AM
06/02/14 03:34 AM
Australia
big_wedge Offline
big_wedge  Offline
Australia
stock steel duster hood 50lbs fiberglass duster hood 12lb
Re: glass hood question. [Re: 383man] #1627428
06/02/14 11:13 PM
06/02/14 11:13 PM
8
80arrow Offline OP
80arrow  Offline OP
So you left the front fenders on then? That would probably be easier to pull the doors then the fenders the way it looks to me.
Re: glass hood question. [Re: big_wedge] #1627429
06/02/14 11:15 PM
06/02/14 11:15 PM
8
80arrow Offline OP
80arrow  Offline OP
that would be nice to lose 38 lbs off my car thanks
Re: glass hood question. [Re: 80arrow] #1627430
06/03/14 10:31 AM
06/03/14 10:31 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes thats what we felt that removing the doors was easier then removing the fenders and I feel it was. Course you need atleast one other person to help put the doors back on. We just used a floor jack with rags on the lifting plate of the jack so not to scratch the door. Then had a friend guide the door to the hindge. And once bolted on we then aligned the door to the marks and double checked it before the door was closed. Ron
Re: glass hood question. [Re: 383man] #1627431
06/03/14 08:20 PM
06/03/14 08:20 PM
8
80arrow Offline OP
80arrow  Offline OP
That sounds like the way I'll do it then. Thanks, Ron
Re: glass hood question. [Re: 80arrow] #1627432
06/04/14 03:38 AM
06/04/14 03:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Glad I could help. Ron
