Chevy thrust bearing clearance #1627209
05/31/14 10:10 PM
05/31/14 10:10 PM
Tennessee
WyleECoyote Offline OP
Tennessee
Taking the advice of a fellow-Mopartian, I've disguised this thread because I wasn't sure where to stick it - and I've been assured a Mod will park it correctly. Would this be considered "Thread Valet"?
My 84 D350 Crew Cab; 2 doors are hard to open like the dickens from the outside - but if I reach in and use the inside handle, they open with ease. Is this an adjustment that can be made if I tear it apart and work on it? Has metal fatigued or bent? Is something worn out?
Thanks!
Re: Chevy thrust bearing clearance [Re: WyleECoyote] #1627210
05/31/14 10:28 PM
05/31/14 10:28 PM
Alberta
rustbuckett68 Offline
Alberta
Check and see if the outside handle actuator rods are bent. This happened on a 92 regal kind of car. Gave them a tweak, and it works good, until next winter when the doors freeze.
Re: Chevy thrust bearing clearance [Re: WyleECoyote] #1627211
05/31/14 11:16 PM
05/31/14 11:16 PM
The opening with ease is a very good sign to me that either an adjustment or a minor piece that can be replaced/repaired will take care of this as opposed to the whole shebang being fubared & needing major body work
