How much fluid in a Dana? #1626811
05/30/14 08:31 PM
05/30/14 08:31 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
What is the correct fluid capacity for the Dana 60 in my race car? I am confused by what the service manual says.
On another note, do some of the Mopar rears use different capacity based on whether it is an open or suregrip diff?
Re: How much fluid in a Dana? [Re: markz528] #1626812
05/30/14 08:37 PM
05/30/14 08:37 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
believe we put a qt and a half in ours. Drag only w/t spool.
Re: How much fluid in a Dana? [Re: markz528] #1626813
05/31/14 12:13 AM
05/31/14 12:13 AM
Larry Shepard suggested, as did Mopar at that time, to use 1 quart of lube in both the 8 3/4 and the Dana 60 at the old Mopar drag seminars.(drag racing only) That was in 1974 and again several years later at another drag seminar held in Long Beach,CA before Mopar went bankrupt the first time. I put 5.5 pints now(this winter)in my Dana 60 with a 40 spline spoool and axles with one of the aluminum rear stud girdle covers because that is what was in when I bought that car, it wasn't broken with 5.86 Pro gears so I didn't change that fluid level Your choice, I ran 1 quart for many years in both my Dana 60 with a posi and 8 3/4 with spools, no gear failures do to lack of lubrication Your choice
Re: How much fluid in a Dana? [Re: Cab_Burge] #1626814
05/31/14 02:41 AM
05/31/14 02:41 AM
PA
moparacer Offline
moparacer  Offline
PA
I was told buy a very knowledgeable Dana 60 guru to run enough fluid in it to make sure the carrier bearings are being oiled. That means the oil level should be slightly higher than the bottom of the bearings setting still.
Fooled around with fluid levels and never seen enough of a ET difference to make it worth taking a chance.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: How much fluid in a Dana? [Re: moparacer] #1626815
05/31/14 02:52 PM
05/31/14 02:52 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Thanks for all the responses. I put 5 pints in it - that's what came out. I couldn't bring myself to running less..............
