Re: BB Cam bearings, Sealed Power vs Clevite
[Re: Nitrofish]
#1625966
05/28/14 01:57 PM
05/28/14 01:57 PM
Posts: 1,051 The Great White North
RAMM
I think you have that backwards. What is the application? J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: hemiiroc]
#1625969
05/28/14 05:03 PM
05/28/14 05:03 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Go with Durabond
RIP Monte Smith
[Re: Chris2581]
#1625972
05/28/14 07:09 PM
05/28/14 07:09 PM
Durabond PDP-17 is the best thing going The std PD-17 is way better than Clevites and others but the PDP-17 is what most builders use--way less trouble than other brands on fitting--they look like they were made by someone that cares --hold up good to rollers etc the ONLY kind I use--have cut down on time wasting tight cams
[Re: ]
#1625973
05/28/14 09:46 PM
05/28/14 09:46 PM
Posts: 485 Central California
MoParFish
Central California
I had trouble with SP bearings on last build, cam too tight. Tried scraping/shaving and got better but still didn't feel right. Someone recommended Durabond bearings so I removed the other ones and installed Durabond PDP-17s using same tool/method and problem solved with NO scraping whatsoever. Comp solid roller fit perfect.
[Re: MoParFish]
#1625974
05/28/14 11:09 PM
05/28/14 11:09 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Nice to know Fitting my last cam bearings took some time.
[Re: Sport440]
#1625975
05/29/14 02:21 AM
05/29/14 02:21 AM
Posts: 646 VA.
mosweethemi
VA.
[Re: 135sohc]
#1625979
05/29/14 03:49 PM
05/29/14 03:49 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
In reality,believe it or not the split bearings conform better to the block.That does not mean they are any better as far as fittment.In fact that is likely why people have more problems w/them.The factory always used the split bearing.Of course if you are machining them in the block it doesn't matter.All the bearings will work fine most problems have more to do with installation.Bottom line is some will need extra work to fit correctly.
Leave the gun.......take the Cannoli's....Mike
