1990 B350 5.9 360 Has Fuel but no spark. UPDATE!!
#1625453
05/26/14 11:11 PM
05/26/14 11:11 PM
Posts: 433 St.Clairsville Ohio
EV2RUNNER
St.Clairsville Ohio
Hey Guys Hopefully someone can help me here. I have a 1990 Dodge B350 van with only 70,000 miles and an efi 360. Anyway The van was running fine until I went to start it today, it has fuel but no spark. I changed out the coil and ECM to no avail. I even tried to "Hotwire" the coil with 12V to the Pos. side and got no spark?? Could this be the hall effect sensor in the distributor? I have been told ASD relay but my thinking is if it was bad I would not be firing the injector correct? Any insight would help, I really wanna get this thing home. Thanks
Re: 1990 B350 5.9 360 Has Fuel but no spark.
[Re: EV2RUNNER]
#1625454
05/26/14 11:23 PM
05/26/14 11:23 PM
Posts: 1,004 ohio
bbtrux
ohio
90 model, so I assume its TBI....when you say has fuel, pump does run?has pressure?(per spec,on A gauge)..has injector pulse?...if it has those things, take asd off the list.if that's the case,next check is spark tester on coil wire (spark may not be making it out of distributor due to bad cap or rotor).if coil makes no spark,check for positive voltage at positive side.on neg side,a test lamp should flash while cranking.not familiar with TBI as I am magnums.do they have crank sensors,or use the pickup for everything?crank sensors are real common on magnums.
[Re: EV2RUNNER]
#1625456
05/27/14 12:14 AM
05/27/14 12:14 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
did you try to run the codes?
The Key on-off-on-off-on-off method should get the check engine light to flash. Then post the codes.
[Re: EV2RUNNER]
#1625461
05/27/14 06:14 PM
05/27/14 06:14 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
If its TBI which it should being a 1990 then it does not have a crank sensor as it only needs the dist hall effect since it does not have 8 injectors to fire at the right times. Of course the dist signals the PCM to fire the coil and the PCM just fires the 2 injectors in the throttle body by the dist hall effect count and just squirts the fuel into the intake sorta like a carb. They did go to a seperate fuel pump and ASD relay but I think it was 1992 when they did which was the year they went to ported fuel injection with 8 injectors in the intake. So if yours has just the ASD relay to feed the coil and throttle body injectors and you have power to the injectors you must have a wireing problem if you have no power to the coil when the eng is cranking. You did say the coil has no power when cranking the eng right ? Ron
[Re: 383man]
#1625462
05/28/14 02:56 PM
05/28/14 02:56 PM
EV2RUNNER
St.Clairsville Ohio
Correct No power to coil at startup, Had short injector pulse for a second at startup. Now nothing.Replaced the Hall Effect Sensor still nothing.. I read this on ALLPAR...""For troubleshooting purposes only (don’t drive like this!), Ed Hennessy wrote: “You can try feeding power to the fuel pump directly. Connect 12V+ from the battery through a fused link to the positive terminal of the coil. That will back feed 12V to the fuel pump through the ASD circuit. If the pump runs [it should be easy to hear], the ASD relay is bad. If not, the fuel pump or its wiring is probably the problem."" I tried it.. The Fuel pump did run, Took a Known Good ASD From my 95 Dakota, tried 12V to + on coil, pump still ran.. So I don't think the ASD itself is bad. I guess its time to start probing wires...Uhhhgghh
[Re: EV2RUNNER]
#1625464
05/28/14 03:13 PM
05/28/14 03:13 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Those were known for coils going.I changed a bunch at work.Also did you check the coil lead itself?You wont have spark if either the coil or the coil wire is bad.Rocky
Chrysler Firepower
[Re: therocks]
#1625465
05/28/14 08:55 PM
05/28/14 08:55 PM
Supercuda
About to go away
About to go away
up yours
The coil has two required things going to it. A steady 12v and a pulsed ground. If you have a test light you can clip it to the two terminals on the coil and it should pulse as you crank the motor. If it does your coil or the coil lead is suspect. You can ohm out a coil. http://autorepair.about.com/od/troubleshooting/ss/coil-test-ohm.htm
[Re: Supercuda]
#1625466
05/28/14 09:27 PM
05/28/14 09:27 PM
Posts: 2,601 Great White North
Furyman
Great White North
i've got an 89 maxipad 360 efi.That vintage van has a bunch of fuse links running up behind the booster.Mine fried one...no start.Still have all the spare new stuff (puter,etc) that i threw at it before I figured it out.
"Long Live Mopars"
