Duster rear window seal, not forming to headliner.
#1624435
05/24/14 04:16 PM
05/24/14 04:16 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
The rear window seal on my Duster ir not forming to the headliner very well, will it eventually relax and fit better or do I need to do something?
Is it suppose to be glued or attached somehow? Here's a photo...
Re: Duster rear window seal, not forming to headliner.
[Re: ProSport]
#1624437
05/24/14 04:23 PM
05/24/14 04:23 PM
Posts: 13,583 md
mopars4ever
md
[Re: ProSport]
#1624438
05/24/14 04:30 PM
05/24/14 04:30 PM
Posts: 27,467 So Cal
autoxcuda
So Cal
Is it a repro or original rear window seal?
The Duster Demons do not get a seperate cover piece like the Dart you have pictured.
Sort of looks like the seal isn't sitting right in the channel with the window so that is forcing the lip to stick up. Was the lip sitting ok before you put the headliner in. If so, maybe when you pulled the lip back to get the headliner tucked in, it pushed/moved the rubber/body-lip/glass joint out of place.
If you have the rear window molding on, take if off and see what going on with the other side of that lip that sticking out. Maybe you will see something that doesn't look kosher.
