Rubber a-body disc brakes lines on an b-body? #1623657
05/22/14 04:43 PM
05/22/14 04:43 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
I'm at work and can't check my catalogs for the info. My buddy has put 1974 a-body disc brakes on a 1969 roadrunner and needs the correct rubber lines for the conversion. Anybody know which rubber lines to use for it?
Re: Rubber a-body disc brakes lines on an b-body? [Re: migsBIG] #1623658
05/22/14 04:52 PM
05/22/14 04:52 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Should use the ones for 80-89(?) diplomats . . . same for the calipers, as they have the inlet on the bottom and bleeder on the top, opposite the brake hose inlet . . . check with doctor diff. He has nice stainless steel hoses for sale . . .
Re: Rubber a-body disc brakes lines on an b-body? [Re: migsBIG] #1623659
05/22/14 05:10 PM
05/22/14 05:10 PM
IDK about correct but I used 78 volare hoses when I added 74 A discs to my 65 dart. It's a little bit longer than OE & is needed for that app. I just cutoff half of the metal bracket that is crimped on in the middle of the hose. If that hose will solve your app you'll see what I mean regarding the bracket when you lay eyes on it. Otherwise here's a BTT for ya
