A big thanks to Todd Marsh @ Marsh Performance #1622756
05/20/14 09:12 PM
05/20/14 09:12 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Just got off the 'phone with Todd. He's just finished our 655 motor it made some great number on 93 octane and 11:1 compression. So much in fact, we now have the potential to run an 8 second pass at 3900lbs. The motor certainly has it, we just need to get the chassis working at this side of the pond.
Thanks Todd
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: Tig] #1622757
05/21/14 02:26 AM
05/21/14 02:26 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Thank you Tig for the chance to build this monster. Also thanks to Mike Barret and Larry Smith @ MEM race engines for all of their fine work and contributions.
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: sasquatch] #1622758
05/21/14 09:02 AM
05/21/14 09:02 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Great stuff, cant wait to see it go down the track.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: Tig] #1622759
05/21/14 10:19 AM
05/21/14 10:19 AM
an8sec70cuda Offline
Very nice! Any details on the combo and what it made on the dyno?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: an8sec70cuda] #1622760
05/22/14 10:21 AM
05/22/14 10:21 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Hi Chip, Motor made 1042 hp @ 6400 and 950ft/lb @ 5300 on Todds dyno. 11:1 cr with 93 octane. Pump gas motor, racing fuel is so expensive over here. It's a 655ci Indy block with 600-13 heads, raised cam, 4.840 bore centre line. Cast intake 2x4. Wet sump. Should be very streetable
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: Tig] #1622761
05/22/14 10:31 AM
05/22/14 10:31 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Dang that sounds like a beast!
We need some pictures
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: Tig] #1622762
05/22/14 10:48 AM
05/22/14 10:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Very nice... cudos to Todd
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: roadhazard] #1622763
05/22/14 12:17 PM
05/22/14 12:17 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
So do I
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: Tig] #1622764
05/22/14 01:20 PM
05/22/14 01:20 PM
Simply bada$$. Can't wait to see pics and hear how it runs. I'm gonna need some video...stat. Thanks.
CHIP
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: an8sec70cuda] #1622765
05/22/14 08:16 PM
05/22/14 08:16 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
WOW! That's a lot of steam for pump gas!
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: Bigcube] #1622766
05/23/14 02:01 AM
05/23/14 02:01 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Recipe for engine.
Carbs Massive.
Intake Cavernous.
Heads Gigantic.
Valves Platter like.
Pistons You could bathe babies in the dish.
Cam Not as big as you think.
Crank and rods Big.
Rockers Expensive.
Cost Really Expensive.
Seriously if Tig oks it I will share some more info but only with his blessing. It is his now.....And yes I will take some pictures of it. Honestly other than the gen 3 dominators it looks like a big INdy wedge with a Milodon pan and belt drive.
Oh and the requested purple wires......
Todd
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: sasquatch] #1622767
05/23/14 02:09 PM
05/23/14 02:09 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Hi Todd.
I don't have a problem with you giving out the details,
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: Tig] #1622768
05/24/14 12:43 AM
05/24/14 12:43 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
ok here ya go.
Indy max block with raised cam and 4.84 bore space. Clearanced for a 5 inch Callies crank and 6.95 GRP rods. Lots of clearance grinding. Standard Milodon dual line with Swinging PU. Pistons are custom Diamonds with a 33 cc dish. They look like diesel pistons. 043 ring low Tension oil ring. Jesel belt drive up front. A few custom touches to the block to aid in drain back. 55 mm flat bearing cam with a 4/7 swap. 7/16 Manley pushrods, COmp ultra pro lifters. 1.8 Jesel rockers slamming 2.450 1.81 Titanium valves in 600-13X heads with our full port treatment. Copper head gskt and ARP hardware. INdy tunnel ram with the full treatment and two 1150s GEN 3 dominators. Msd Probillet and Taylor PURPLE wires. ATI dampner and Tig has a crank trigger for it. I ran it with a Star Machine Vaccuum pump. It pulls over 800 ft/lbs from 4000 to 7000 with peak at 5400 of 950.
I layed this motor out with the help of Mike Barrett and head and manifold guru Larry Smith. We had to be really careful with this one due to the low compression. We had previously only done these with Big compression and cams. Cams ah yes. All I will say about that is it has .485 lobe lift. I will post some pics tommorrow.
Good night all.
Todd
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: sasquatch] #1622769
05/24/14 01:06 AM
05/24/14 01:06 AM
I would add
That is one of the truest dynos in the land--those numbers are REAL
Congrats on a Wicked Mopar build!!!!!!!
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: ] #1622770
05/24/14 01:24 AM
05/24/14 01:24 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Really impressive Todd. All of your effort paid off. IMO, Todd is the best Indy dealer to work with, or any parts for that matter. Not dissing any of the other guys, he's just very savvy and honest. Steve gill does well too.
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: camastomcat] #1622771
05/24/14 01:28 PM
05/24/14 01:28 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Awesome....Really pleased
Looks like we're getting a handle on the chassis tune. We've just smashed the crown wheel and pinion in the Dana
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: Tig] #1622772
12/04/14 02:19 PM
12/04/14 02:19 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Todd did me right.. ...only place I'll go from now on ...!!!
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: Tig] #1622773
12/04/14 02:51 PM
12/04/14 02:51 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Over 1000hp and 873 lift, that'll sound good pulling into the root beer stand.
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: Tig] #1622774
12/04/14 04:01 PM
12/04/14 04:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
WOW is all I can say............
Re: A big thanks to Todd Marsh @ Marsh Performance [Re: Thumperdart] #1622775
12/04/14 04:10 PM
12/04/14 04:10 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I will second that!
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
