Re: How long should a power brake booster hold a vacuum?
[Re: rxod]
#1621546
05/18/14 04:01 PM
05/18/14 04:01 PM
Posts: 25,955 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Well, it's supposed to hold vacuum long enough to make at least a couple of engine-off stops. If the check valve and its grommet are good the diaphragm must be leaking.
Can you hear any leakage immediately after the engine is shut off?
