headliner removal - 69 b-body ?? #1620218
05/14/14 11:30 PM
05/14/14 11:30 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
How do the bows come out of their retainers ??
What holds the sail panels on ??
Thanks,
Re: headliner removal - 69 b-body ?? [Re: Stanton] #1620219
05/15/14 11:58 AM
05/15/14 11:58 AM
Spokane Washington
P
pro-streeter Offline
P
Spokane Washington
Sail panels are held on with push clips like used on door panels.
As for the bows they set in triangle shaped cups so if you pull the head liner loose from the front or back glass area first you can push the bow forward or backward to remove tension. They lift out pretty easy then. Keep them in order as they are different.
Re: headliner removal - 69 b-body ?? [Re: pro-streeter] #1620220
05/15/14 11:47 PM
05/15/14 11:47 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Thanks. Got everything out. The bows are color-coded but I marked them anyway.
