Re: What stall? [Re: Sport440] #1619980
05/15/14 11:27 PM
05/15/14 11:27 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Thanks of all of the great replys to my original post guys!
Anybody want to buy my hydraulic roller cam, lifters and my PTC converter?
Re: What stall? [Re: ccdave] #1619981
05/15/14 11:36 PM
05/15/14 11:36 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
So you have a PTC vert. You Never said that before. The post before mine stated 9.5, figured you had a Dynamic.
What was its stall numbers/combo before the new build.
Re: What stall? [Re: ccdave] #1619982
05/15/14 11:44 PM
05/15/14 11:44 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
It's a 9.5" converter. They are just going to tighten it up a bit.
Thats all the prior Vert info you gave.
No stall/flash etc. Didnt know PTC had a 9.5 too.
More info on your current vert with whatever combo you had before would be helpfull.
If the PTC is loose/sloppy then by all means have it tightend with the new combo for 300 bucs or so.
Re: What stall? [Re: Sport440] #1619983
05/15/14 11:44 PM
05/15/14 11:44 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
My current combo is a 440
3:91'gear
4100 stall
Re: What stall? [Re: Barnstorm] #1619984
05/16/14 11:28 AM
05/16/14 11:28 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Project Orange Monster #4 is underway
This motor will be a RB 505ci with E RPM heads, hyd roller, Indy dp intake, 3:23 gear 3450 pounds with me in it. 90% street driven
What stall would be good for this combo??
3800 flash works well on the street with 3.23's...and is tite enough at 60mph for some mpg etc..you won't loose the burn out contest...get a name brand. Call your specs in.
Thanks Barnstorm
Thats what the boys at PTC said as well
Re: What stall? [Re: ccdave] #1619985
05/17/14 01:06 AM
05/17/14 01:06 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Thanks Barnstorm
Sounds like the PTC vert is as tight as the Dynamics 9.5 verts. If so , Id try it as is too.
Barnstone, PTC, Sport, and others agree. What you have should be fine.
Re: What stall? [Re: Sport440] #1619986
05/19/14 12:23 AM
05/19/14 12:23 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
I will leave that up to PTC to decide
