Dodge Caravan transmission ???? #1618403
05/10/14 04:45 PM
05/10/14 04:45 PM
Back home in PA
BulletBob Offline OP
Back home in PA
My Daughter recently had the trans die in her 95 Grand Caravan Conversion I have since found a 94 with less miles cheap & was wanting to know if the trans will interchange & what needs to be retained from the original if needed
Thanks ahead! Bob
Re: Dodge Caravan transmission ???? [Re: BulletBob] #1618404
05/10/14 05:02 PM
05/10/14 05:02 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Not 100% ,,but I'm pretty sure they are the same.
provided they are like engines obviously.
Re: Dodge Caravan transmission ???? [Re: gtx6970] #1618405
05/10/14 05:06 PM
05/10/14 05:06 PM
Back home in PA
Back home in PA
Hers has a 3.3 & I'm going to look at the other van in a bit & check it out Thanks Bob
Re: Dodge Caravan transmission ???? [Re: BulletBob] #1618406
05/10/14 05:57 PM
05/10/14 05:57 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
If you call a junkyard they might look it up for you in their Hollander.
