Door Latch - 76 D100 HELP!!!! #1617640
05/08/14 11:34 AM
05/08/14 11:34 AM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
I'm hoping someone can help.. I need a info on passengers side (RH) door latch assembly for my 76 D100. Does anyone have a part number for the RH door latch? Apparently the latches changed in the mid 80s can anyone confirm this? Will a latch from an 85-93 truck work on a 76? Thanks Josh-
Re: Door Latch - 76 D100 HELP!!!! [Re: jstollfu] #1617641
05/08/14 01:03 PM
05/08/14 01:03 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
85 up the striker got bigger. Thats why its different. If you need one I can pull one but have to wait till sunday.
Re: Door Latch - 76 D100 HELP!!!! [Re: jstollfu] #1617642
05/08/14 02:49 PM
05/08/14 02:49 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
Latches from 72-84 are the same which is the big striker, then 85-93 had the small striker, you can use the 85-93 latch as long as you use the small striker along with it , had to do this before on my 81 stepside which I had 86 doors put on it with the small striker, worked just fine
Re: Door Latch - 76 D100 HELP!!!! [Re: jstollfu] #1617643
05/08/14 05:00 PM
05/08/14 05:00 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Thanks for the responses! PM's sent. Josh.
