Re: pro's/con's low tension oil rings
[Re: rebel]
#1616841
05/06/14 06:55 AM
05/06/14 06:55 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
Pro's; it takes less power to turn the engine over con's; They don't their job as well as the standard tension rings, unless you are usin a vacuum pump.
Plynouth VIP '67 TT IC EFI
[Re: rebel]
#1616842
05/06/14 09:38 AM
05/06/14 09:38 AM
Posts: 10,006 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Each combo will be different, but the basics are just how much oil gets by the ring you use. Acceptable for a race motor and a street motor are different. A race motor can burn more oil because we don't care about oil consumption in a race motor. The problem is when too much oil gets by the rings then it lowers the octane of the fuel used.
[Re: rebel]
#1616843
05/06/14 11:52 AM
05/06/14 11:52 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
For anything that sees the street, I would not use low tension rings or a vacuum pump. Stick w/ std. tension rings and some vent lines from the valve covers to a puke tank.
[Re: rebel]
#1616845
05/06/14 03:59 PM
05/06/14 03:59 PM
Posts: 43,193 Bend,OR USA
Cab_Burge
Two things come into my mind on piston rings, thickness of the face and the tension. I'm almost positive that all the new cars have thinner piston rings than before, 5/16 inch face old days, 1.5 MM or 1.0 MM rings now The last stroker motor I built for myself has 1.5 MM top and 2nd MM rings with a 3.0 MM low tenison oil rings, no vacume pump or crankcase evac. system, two breathers on each valve cover I forgot to measure the rotational break away and rotataional torque but it is a bunch less than the other motors with 1/16,1/16, 3/16 standard oil tension ring set that I have built My next motor will have 1.0,1.0, 3.0 MM low tension rings with a vacume pump Let us know what you decide
