opinions of Super flow 110 #1616776
05/05/14 10:29 PM
05/05/14 10:29 PM
Vermont
bracketcharger Offline OP
Vermont
Looking for input on the superflow 110 flowbench. Thanks.
Re: opinions of Super flow 110 [Re: bracketcharger] #1616777
05/06/14 01:14 AM
05/06/14 01:14 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
its a bank of manometers and a vacuum source .
as long as its vacuum is consistent and repeatable.
then it should be fine...all you are doing is measuring the change from before and after mods.
unless you are looking to pull for sonic choke
or specific fps air speeds that are greater than the vacuum the machine is capable of .
or volume.
then its a capable tool...
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: opinions of Super flow 110 [Re: bracketcharger] #1616778
05/06/14 05:07 AM
05/06/14 05:07 AM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
hi, go to super flow web site. they have all informtion listed. and a contact person, beat way to find out correct information.
Re: opinions of Super flow 110 [Re: perfmachst] #1616779
05/06/14 08:20 AM
05/06/14 08:20 AM
Vermont
Vermont
Thanks for the replies. I bought a used 110 last Saturday. It's literally a like new machine. It came with the operators manual so I've got some studying to do.
