Ebody rear window clips, two are different??? #1615575
05/03/14 05:48 PM
05/03/14 05:48 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
I am getting ready to install the rear window and trim clips on my 74 barracuda. I bought the clips from dante last year and just opened the bag. There are about 18 green clips and two bronze colored ones with screws. So where do they go?
Re: Ebody rear window clips, two are different??? [Re: cudabitten] #1615576
05/04/14 12:11 PM
05/04/14 12:11 PM
California
1970mopar Offline
1970mopar  Offline
California
lower corners on the bottom of the window channel. There should be two screw holes fairly close together. Moulding clips are spaced evenly, the other two screw holes are for the odd clips.
They help to align the glass in the window channel while setting the butyl rubber.
