84 FITH AVE REAR #161440
12/05/08 12:12 AM
12/05/08 12:12 AM
L.I. N.Y. Hemi Street
HemiGreg Offline OP
HemiGreg  Offline OP
84 FITH AVE REAR SHOCKS.
I NEED AIR SHOCKS FOR REAR OF FRIENDS TOW CAR(BOAT)BUT NO ONE SEEMS TO LIST THEM.
WHAT OTHER BODYS AND YEARS WILL WORK?
IM SURE THERES TONS
Re: 84 FITH AVE REAR [Re: HemiGreg] #161441
12/05/08 09:12 AM
12/05/08 09:12 AM
scratchnfotraction Offline
try an R-body
gran fury,diplomat,mid-80s wagon
what ends are on the stock shock?2 eyeloops? or 1eyeloop and a stud/nut (bayonet style)
I allways buy them for a B-body and get the ones that have the sleeve over the air bag(highjackers)
you can get a set of overload shocks that have a coil spring on them also,they would work nice with out the hassel of air lines
you could try the bolt on overload springs from JC-W that clamp on the rear of the leaf spring,I see them a lot on the 5th ave,s,probly JC-W also
I have had good luck with napa finding the coilover shocks and air shocks
Re: 84 FITH AVE REAR [Re: scratchnfotraction] #161442
12/05/08 09:35 AM
12/05/08 09:35 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
5th ave, diplomat, gran fury, pre 83 lebaron, are all M's.
the shocks interchange with J's (mirada, 80-82 cordoba, 80-82 imperial) and F's (aspen/volare)
they have an eyelet on the top, bayonet on the bottom. I don't know if a late B or R has the same shock layout, since they also have the isoclamp system.
shock mounts were never designed to carry vehicle weight. Air shocks and coil-over helper shocks. and are a bad idea to try increase rear ride height and load carrying capacity. the right way to do it is to get better springs or overload springs. a new set of 5 leaf HD police spec springs should run less than $250 from ESPO. they added over 2" of rear height to my 5th ave over the stock sagging 4 leafers....conversely, over on dippy.org's forum, bill55az has found the front segment to be the same length as a dakota, and has used dakota rear springs with good success on his old M body wagon with some mods to the rear spring hanger.
2017 Grand Cherokee Overland
Re: 84 FITH AVE REAR [Re: patrick] #161443
12/05/08 11:07 AM
12/05/08 11:07 AM
my bad,I get the m,f,r thing fused up
fords had a lot of shocks that had the bayonet bottom end
surly you can find something to fit
I am with patric on the ride height thing,not a good idea with the air shocks...but for hauling and ride control they can be helpful
thats what they are for,not lifting the car itself,just level the load/ride while hauling a boat ect....
Re: 84 FITH AVE REAR [Re: scratchnfotraction] #161444
12/05/08 01:58 PM
12/05/08 01:58 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if you MUST have them, check out monroe PN MA750 (air shocks) or 58587 (sensa-trac load leveling coil overs)
they're both under $70/pr at rockauto.com
Re: 84 FITH AVE REAR [Re: patrick] #161445
12/05/08 11:02 PM
12/05/08 11:02 PM
HemiGreg Offline OP
HemiGreg  Offline OP
