Milodon SB 8 quart pan vs. 7 quart lowpro pan?
#1613777
04/29/14 09:45 PM
04/29/14 09:45 PM
Posts: 3,414 Toronto
mshred
Toronto
I am getting a new oil pan for my small block to replace my kevko pan (Barely holds 5 quarts in the pan!). In specific I am looking at the Milodon 8 quart pan (p# 30940) and the 7 quart low pro version (p#30941). My Kevko pan from top rail to the bottom of the sump is 8". The 8 quart Milodon is 8-3/4". The 7 quart is 7-3/4", so slightly shorter then my Kevko. There is a drastic difference in price, with the low pro pan being more expensive (and also having a raised rear portion behind the sump which seems strange to me as it might trap oil, but according to Milodon helps oil control?). I am struggling in deciding which pan to go with. I don't think another 3/4 of an inch will give me any clearance issues, and both pans are SUPPOSED to clear my TTI 1-7/8 race headers. I am wondering what others are running, what their ground clearance is like, and more importantly, if the insides of the pans are different at all? I don't mind spending the extra money on the low pro IF the oil control inside is better (and the shorter height overall is obviously a bonus also). Here is a link to the Milodon website (the sb pans are at the bottom of this page) http://www.milodon.com/oil-pans/street-oil-pans-chrys.asp
Re: Milodon SB 8 quart pan vs. 7 quart lowpro pan?
[Re: mshred]
#1613778
04/29/14 09:49 PM
04/29/14 09:49 PM
Posts: 311 Colorado Springs, Colorado
Dartthunder340
I am using a Milodon pan and TTIs with no issues. Very happy with everything so far. I am fairly low in front with no issues for clearance so far, well aside from the headers dragging on the trailer stuff.
edit* I should add that it is the 8 qt. Drag car only.
Better get inside Ma. Looks like a storm's comin'.
[Re: Dartthunder340]
#1613779
04/29/14 10:06 PM
04/29/14 10:06 PM
mshred
Toronto
My old hookers tended to drag on the trailer (The collectors) but the new TTi's should be better. Here is a pic of the ground clearance I had with the kevko...as I said, I don't think 3/4 of an inch will make much of a difference, but I am also concerned about the internal design of the pans. What is the 8qt like on the inside?
[Re: mshred]
#1613780
04/30/14 12:02 AM
04/30/14 12:02 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I have the 7 quart in what appears to be an older version. Mine does not have that little kick up area behind the sump, its flat there. Clears my TTI headers with zero trouble but did require a small notch on flat lip of the K-frame nothing major.
My car sits pretty low and I would be afraid to go to the deeper pan. Mainly because I live in Oklahoma and our roads are terrible.
68 Barracuda Formula S 340
[Re: Bad340fish]
#1613781
04/30/14 12:07 AM
04/30/14 12:07 AM
mshred
Toronto
I should have mentioned I sectioned a section out of my k-frame back when I first assembled the car, so this pan should clear with no problems.
Our roads are torn up here pretty bad also. I have thought about lowering my car a tad more once I switch to the TTI's this year (they might tuck up tighter then the hookers I had pictured) but I am fine with the ride height as is.
Do you have a pic of the 7 quart pan on your car to get an idea of ground clearance??
[Re: mshred]
#1613782
04/30/14 12:19 AM
04/30/14 12:19 AM
Bad340fish
Tulsa OK
Quickest reference I could find.
[Re: Bad340fish]
#1613783
04/30/14 12:31 AM
04/30/14 12:31 AM
mshred
Toronto
That pic definitely does help
And you weren't kidding when you said your car is low lol
[Re: mshred]
#1613784
04/30/14 12:37 AM
04/30/14 12:37 AM
Bad340fish
Tulsa OK
yeah, it looks cool but needs to be higher. I keep putting off buying new mono springs(has -1s on it now).
[Re: mshred]
#1613787
04/30/14 12:18 PM
04/30/14 12:18 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Go w/ the low profile pan. 1" is huge when it comes to oil pan ground clearance on a street driven car. I had a deep sump Milodon pan on my Hemi...at the time I built the motor they didn't make a low profile pan for the external p/u systems. After smashing it up a few times I got tired of repairing it. Last year when I freshened it up I bought a new low profile pan for it. Very happy I did.
[Re: an8sec70cuda]
#1613788
04/30/14 12:27 PM
04/30/14 12:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Really would depend on the headers... if the headers are lower than the pan then it doesnt matter.. I tend to build my headers to protect the pan... I build my pans and headers so I can replace either but I dont want the pan getting ripped open.. this is on my Rampage and I built a 9 qt pan... baffles and trap doors inside it
[Re: MR_P_BODY]
#1613789
04/30/14 12:30 PM
04/30/14 12:30 PM
an8sec70cuda
The headers won't be a factor if you scrape a crown in the road.
[Re: MR_P_BODY]
#1613791
04/30/14 12:52 PM
04/30/14 12:52 PM
an8sec70cuda
Down here we get bad crowns and ruts on a lot of the roads at redlights due to the summer heat and beach traffic. In some areas they are unavoidable. In that type of situation, the headers will not be any help shielding the pan. All depends on how low your car is and what type of roads you drive on. I'll take the shortest possible pan.
[Re: an8sec70cuda]
#1613792
04/30/14 12:56 PM
04/30/14 12:56 PM
Posts: 5,161 CT
GTX MATT
CT
The Milodon low pro pan isn't that low
[Re: mshred]
#1613793
04/30/14 12:59 PM
04/30/14 12:59 PM
Posts: 7,506 Az
Crizila
Az
I run the 30940. Had to notch the K member in my application. Hangs just below the K member also. The center link just touches the back of the pan on hard ( lock to lock ) turns.
Fastest 300
