Power to Manual brake question... #161220
12/04/08 07:11 PM
12/04/08 07:11 PM
Weatherford, Texas
RapidusMaximus Offline OP
Weatherford, Texas
My 68 Plymouth Satellite came with power drum brakes...I decided to change it over to manual since it's going to be a street/strip car...I ordered a conversion kit from Mancini and the adapter plate mount holes don't line up with the same holes as the power brake booster mount holes...does this thing require that I center it with the round hole in the firewall (pushrod hole) and then drill 4 new holes...or did they send me the wrong adapter plate? pn is AR6719...thanks...(Mancini is already gone for the day and I was going to work on it tonight)...don't mind drilling the holes and it won't be that bad...just would like to make sure before drilling away...thanks again...
Re: Power to Manual brake question... [Re: RapidusMaximus] #161221
12/04/08 09:33 PM
12/04/08 09:33 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
When i converted my Charger from power to manual,,,,i had to get the correct "manual" plate for the firewall to mount the MC....
I got a used one from Tony Dagustino here on the board.....
I dont recall having to do any drilling....
I just pulled off the old booster,,,MC,,,push rod,,,,,installed the new "manual plate",,,got an adjustable pushrod ( or a rod for a manual ),,,and put on a different MC.....
sorry i dont have any pics.........
Re: Power to Manual brake question... [Re: 69CHARGERMD] #161222
12/04/08 09:39 PM
12/04/08 09:39 PM
Weatherford, Texas
Weatherford, Texas
Thanks...you're description is what I thought I would be doing also...
Re: Power to Manual brake question... [Re: RapidusMaximus] #161223
12/05/08 06:26 PM
12/05/08 06:26 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
In 66 there were different firewall support plates for manual vs power brakes. I suspect 68 is the same. Also, there may be linkage on the brake pedal that needs to be removed. There was on my 66 Coronet.
Re: Power to Manual brake question... [Re: Lefty] #161224
12/05/08 06:41 PM
12/05/08 06:41 PM
Weatherford, Texas
Weatherford, Texas
I called Mancini today and they said the plate I have is only to convert manual brakes from old style master cyl to new style...? So now I guess my question is can I drill 4 new holes and just mount the adapter plate through the existing backing plate as long as I center the master cyl over the push rod hole in the backing plate and firewall?
Re: Power to Manual brake question... [Re: RapidusMaximus] #161225
12/05/08 06:47 PM
12/05/08 06:47 PM
yes. If there isn't an adapter(4bolt to 2 bolt) made for this( I do not know B bodies) then center it as you said & drill & you're good.
Re: Power to Manual brake question... [Re: RapidRobert] #161226
12/05/08 06:51 PM
12/05/08 06:51 PM
Weatherford, Texas
Weatherford, Texas
Sweet...thanks
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
