Just finished the electronic ignition conversion on my 72 Dart.
With the key in the ON position,I have power on both sides of the Ballast resistor,Both sides of the coil and the red wire coming out of the Harness that plugs into the Electronic ignition box.
Is there anywhere else I need to check for power and what should the results be in those places?
The reason I ask is because I just tried starting the car for the first time since completing the conversion and it wouldnt start,now im thinking maybe the carb could be dry as well,its been sitting a long time.
