Re: Turning the steering wheel causes the Horn to beep!
[Re: rabid scott]
#161156
12/04/08 04:19 PM
12/04/08 04:19 PM
RapidRobert
That's gotta be embarrassing!. Take off your horn ring or what ever you have there & look at the wiring at the top of the steering wheel where it gets grounded by the horn button & see what's catching & making it ground as you turn the wheel.
[Re: GTXKen]
#161158
12/04/08 04:34 PM
12/04/08 04:34 PM
Posts: 1,884 Tracy CA
rabid scott
"You're Where?"
"You're Where?"
Tracy CA
Hmmm... I'll have to check it that. My steering wheel looks like this: Any tips on taking it apart without destroying anything? There appears to be two places I could remove things, the pad between the three buttons, and the whole center that has the buttons on it?
[Re: rabid scott]
#161159
12/04/08 05:25 PM
12/04/08 05:25 PM
RapidRobert
that jogged my memory, that the whole wheel needs to come off to get at the copper circular ring where the black wire is grounded to sound the horn & see what's hanging up in there. Look on the back side of the wheel for any screws to undo the black cover pieces in the pic so you can get at the big nut.
[Re: sbhpcb]
#161161
12/08/08 08:41 PM
12/08/08 08:41 PM
rabid scott
"You're Where?"
"You're Where?"
Tracy CA
Well, it stopped the random honking, but I'm not really sure the culprit.
I got the little horn pad off, and removed the nut that holds the steering wheel on.
I thought I'd try "He-Man"ing the steering wheel off the splines, and I pulled and pulled, seemed to give a little bit, then I heard a noise.
A small noise, a tiny *pop* almost, if the radio had been cranked, I might have missed it.
Now the horn doesn't sound when the wheel is turned, but still works correctly when the button(s) are pushed.
Should I stop while I'm ahead, wait for the symptom to come back, or keep going looking for what the problem may have been?
What exactly did I do by pulling on the steering wheel?
