Page 4 of 5 1 2 3 4 5
Re: 440 - Eddy 750 - Done. I am happy with result [Re: Steve Bryant] #1611429
05/05/14 11:29 PM
05/05/14 11:29 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
OK, I have two updates:
1) I determined that I did not have the correct plate between my carb and the intake. Performer and RPM manifolds require a cover or gasket that covers and seals the additional carb holes on the intake manifold. Part #9266 or #2732. I bought #9266 to help dissipate some of the heat and I noticed far more consistent vacuum at idle and cruise. The A/F doesn't bounce around anymore.
2) A buddy loaned me his AVS 800 and I am sold. Others have said it, Edelbrock recommends it and I am amazed at the difference everyone told me I would see. As soon as I adjusted the idle mixture and speed it cranked up and I would swear I have a different car.
You guys know that I wanted the 1411 to work and it does. I eliminated the lean stumble, I have a mixture that feels great and the numbers look good on the A/F. Having said that, let me try to explain the difference in raw facts.
1) With the 800, releasing the clutch in 1st gear is like any other car. You just release the clutch, period. No feathering and slipping the clutch. It just works, no matter the load no matter the incline.
2) With the 800, the mixture defaulted to perfect. Cruise is pretty solid around 14.2 and when you punch it you get an INSTANT drop down to roughly 11. As RPMs incrase the A/F increases to roughly 15.0 and then the vacuum kicks in and it drops back down into power mode.
For the most part, I think it has to do with the accelerator pump. When there is a load low in gears and at a start, the A/F is down in the 11.5-12.5 range. There are absolutely no lean spikes anywhere in the RPM range. When I replaced the pump nozzle to a 43, it eliminated the stumble but I still noticed quick lean spikes shifting gears or from a start. The nozzle have a good healthy squirt of fuel but as RPM's increased, the transition would still have a quick little spike that you couldn't really feel but it showed up in the gauge.
Nothing like that with the 800. It is smooth, responsive and a night-and-day difference.
Amazing is the only word that comes to mind.
I am a lot smarter now than I would have been if I had bought the 800 first so I have no regrets but I will say that the 800 is cheaper than a 750 with a tuning kit and nozzle kit.
I will respond back with any comments, questions that may arise but I will say that I HAVE SEEN THE LIGHT.
Pretty Much Sums What I Have Been Stating Within This Thread (And Got Blasted , I Might Add) And Over The Course Of Many Years , 1407/1411s Are Are Are ####
I Basically Went Through This Many Years Ago With My 1407 , However Without An Sensor, What You Have Done Over The Course Of The Last Few Weeks.
I Played/Tuned Mine Over The Course Of A Month Or More , One Summer
I Had To Learn The Hard Way - And In the End When I Thought I Had It Working Pretty Decent, It Was Still A POS Compared To
Last Wednesday , I Said
"Comparing An Edelbrock 800 Thunder AVS With An Edelbrock 750 Is Like Comparing An Hemi With A Slant Six - The Edelbrock 800 Series Is Night And Day Difference OUT OF THE BOX With The 750 Series
Honestly , No Comparison , 800 Series Is That Good !!!"
What I Should Of Said Was
The Edelbrock 800 Series OUT OF THE BOX , Is Still Night And Day Better Compared With A Highly Modified/Calibrated Edelbrock 750 Series Carb
Now I Wish I Could See Some Dyno/HP #s Compared Between The Two Carbs That You Have
I Am Happy You Have Seen The Light
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 440 - Eddy 750 - Done. I am happy with result [Re: Copper Dart] #1611430
05/06/14 12:09 AM
05/06/14 12:09 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
So what do the rest of us do with a BRAND NEW 1407?
Sell It To --- dvw
Siberian Huskies
Re: 440 - Eddy 750 - Done. I am happy with result [Re: Copper Dart] #1611431
05/06/14 09:36 AM
05/06/14 09:36 AM
Georgia
Steve Bryant Offline OP
Georgia
Copper Dart, If you have no problem with the 1407 then I would keep it! My 1411 problems were addressed with larger pump Nozzles and different jets, rods and springs. After a couple of weeks of careful tracking and monitoring my 1411 was tuned to the point where my 440 was pretty happy. I was about to disconnect the O2 sensor and call it a day!
HOWEVER even as happy as I was, last night I sold my 1411 on Ebay for $270 since it was essentially 3 weeks old and I bought an Performer Series EPS 800 cfm from a local parts store for $399. The different of $129 is just slightly more than I spent on the Nozzle kit and jet and rod kit so in my humble opinion, the 800 is a far better deal anyway since the drivability goes through the ROOF the cost difference is negligible.
I think I mentioned earlier that I bought a 800 AVS but that is not correct. I bought the 1413 Performer Series EPS 800 cfm. It looks exactly the same but works like a true champion ALMOST out of the box.
Re: 440 - Eddy 750 - Done. I am happy with result [Re: bee1971] #1611432
05/06/14 09:59 AM
05/06/14 09:59 AM
Georgia
Georgia
Bee,
You were right of course as were many other people that the 800 is tuned better by default. However, I am not convinced the 1407/1411's are junk. They have their place and they can be tuned for many applications. I made the 1411 work and on the Dyno it pulled about 380HP on a fairly tame 440 so its not junk.
I think that if someone has a 1407/1411 and they want to make it better and learn about the Eddy's then its worth getting a kit and making some improvements. (Borrow or Buy an O2 sensor and gauge to make it easier.)
If someone is looking to buy a good carb or they have a 1411 and DON'T want to play with it then I would echo your recommendation to buy the 800 right away. I too will drop in a short note about my experience to provide some context behind my recommendations.
In my experiment, I probably lost $150 buying new carb/parts and selling them and then buying a new carb. I am still happy though as now I understand how to tune these things!
I will pack up my O2 meter and gauge to keep things looking stock and will focus on enjoying life for a little while!
Thanks for everyone's help and advice. You guys are awesome!
Re: 440 - Eddy 750 - Done. I am happy with result [Re: Steve Bryant] #1611433
05/06/14 10:17 AM
05/06/14 10:17 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Steve, I do have issues with the #1407 Carb. Mostly the major bog on acceleration even with a mild roll on the throttle. I too feel the lean hesitation on light acceleration from idle but it doesn't bother me as much as the bog on any brisk application of the throttle. I've contacted Pep Boy's about an exchange to a different Eddy # carb with no response.
What would be a better # for a Stock '68 383 auto?
Thanks again for your Eye Opening and Informative Post!
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: 440 - Eddy 750 - Done. I am happy with result [Re: Steve Bryant] #1611434
05/06/14 11:25 AM
05/06/14 11:25 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
While one CarterBrock may need less work and fewer parts than another to work on our Mopars, none have the features and throttle response of the new Street Demon.
I am not calling the CarterBrocks junk, clearly they can be made to work. But the Street Demon's basic design is better. And it has features that the CarterBrocks don't and that results in a better running carb with less work for our engines.
With the amount of info currently out there about both the Street Demons and the CarterBrocks, I am surprised that people still buy new CarterBrocks.
Master, again and still
Re: 440 - Eddy 750 - Done. I am happy with result [Re: DaveRS23] #1611435
05/06/14 12:09 PM
05/06/14 12:09 PM
Copper Dart Offline
Copper Dart  Offline
Mom.
Ricky Valdes
Re: 440 - Eddy 750 - Done. I am happy with result [Re: Copper Dart] #1611436
05/06/14 12:40 PM
05/06/14 12:40 PM
Georgia
Georgia
Copper, I am glad to help.
I guess it comes down to what do you really want. If you want to get your hands dirty and work with the 1407 then I would consider getting a kit and O2 meter and getting that carb tuned! IF your problem is a lean stumble then timing, idle mixture, pump nozzle and pump arm adjustments should mitigate that problem.
If you are tired of working on it and just want it to work then I would consider replacing it. On Ebay, I just sold my 1411 for about $50 less than I paid for it and I am OK with that considering the current state of my 440!
If you are leaning toward a replacement then would personally look at the AVS 650 for the tamer side and the Eddy 800 for something more aggressive. As someone else pointed out, there are a TON of people who are very happy with Holly and Street Demon. You can't discount the many, many happy posts from those folks.
Not sure why I hang on to the Eddy's. Perhaps its because they look more original to my eye.
Re: 440 - Eddy 750 - Done. I am happy with result [Re: Steve Bryant] #1611437
05/06/14 12:59 PM
05/06/14 12:59 PM
Copper Dart Offline
Copper Dart  Offline
my only chance to exchange it and not cause trouble at the store is to keep the same brand but a different model #. I am looking at the AVS 650cfm Thunder Series model.
Spoke with the store manager (new store wants to establish a helpful reputation in the Hot Rod community )
I really should have done my homework before the impulse purchase.
Mom.
Ricky Valdes
Re: 440 - Eddy 750 - Done. I am happy with result [Re: Copper Dart] #1611438
05/06/14 01:09 PM
05/06/14 01:09 PM
No ACTUAL exp with it but I've heard some good feedback regarding it
Re: 440 - Eddy 750 - Done. I am happy with result [Re: Copper Dart] #1611439
05/06/14 01:19 PM
05/06/14 01:19 PM
Georgia
Georgia
Ricky,
I have no experience with it either but like RapidRobert I have heard no complaints. The lean "flaw" for lack of a better word seems to be primarily focused on the Performer 750.
Re: 440 - Eddy 750 - Done. I am happy with result [Re: Steve Bryant] #1611440
05/06/14 01:34 PM
05/06/14 01:34 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I recommend that you start a thread, get all of the Eddy 750 supporters to pull their money, buy you a good carb, and in exchange one of them can have yours to use every trick up their sleeve to compare it to a real Carter 750, an Eddy 650 or 800, or any Holley 750 and try to get the same power numbers or ET out of it, along with the same crusing A/F ratios, throttle response, etc.
Re: 440 - Eddy 750 - Done. I am happy with result [Re: GTX MATT] #1611441
05/06/14 01:45 PM
05/06/14 01:45 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I just put a edelbrock 1407 on my 413 last week. It replaced a 830 holley with annular downlegs. I basically had the same problems with the holley as this post and the 750 edelbrock fixed it.
The 830 no matter what I did, I could get out the sputter on quick acceleration. It was also too rich even with jet changes, power valve, etc... I used to think I knew holleys
I know how frustrating it can be, but the best thing I did was try another carb. Had a 1406 sitting here and it was like an instant fix, but the motor wanted more fuel unlike too much with the 830.
Far as et, fuel economy, etc... at this point I don't care about any of that. I'm just happy the car runs good, not pig rich and not sputtering
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 440 - Eddy 750 - Done. I am happy with result [Re: Steve Bryant] #1611442
05/06/14 01:58 PM
05/06/14 01:58 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Bee,
1) On the primary side, the AFB and AVS (thunder) are identical carburetors. They also use the same rods, shooters and jets.
2) So Edelbrock got the AVS calibration closer to being correct OOTB for one application than on their AFB. How is this any different from the dozens of people complaining that Holley "x" doesn't work OOTB unless x, y and z is changed out?
I'm so tired of the hypocrites with Holley's who wade into these discussions, by and large I don't see the Carter & Edelbrock folks doing the same thing in the Holley threads. Perhaps I'll start popping in and suggesting a Thunder carb when they start or a nice Atomic EFI setup.
If you find simple jet and tuning changes to a carburetor on a 40 year old muscle car daunting I suggest leaving it to the big boys and go buy a new Mustang.
"I think its got a hemi"
Re: 440 - Eddy 750 - Done. I am happy with result [Re: gdonovan] #1611443
05/06/14 02:29 PM
05/06/14 02:29 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I went through some Carter brochures and came up with the original jet/rod combos for the '68-'71 AVS' used on 383s(630cfm) and 440s(750cfm). Comparing these to the Edelbrock out of the box carb jet combos I can see why folks are having trouble dialing these in. First off I'm setting up a '70 383 Magnum 4 speed Super Bee. Stock intake, exhaust manifolds, TTI 2-1/2" exhaust w/ dynomax turbos, MP electronic ignition.
I set up an Edelbrock 1405 (.089 primary,65-52rods,7 lb. springs,.095secondary, .028 pump jet)and 1411 (.101 primary, 67-55 rods, .089 secondary, .035 pump jet) to see which would work best for my situation. I used the jetting/rod combos from the original AVS' and had a little trouble dialing in the 1411 so switched to the 1405 with a ported wood spacer(Edelbrock 8723) and am very happy with the results. Plenty of low end power and torque which the 1411 wouldn't deliver on my 383. Wish I still had my '73 New Yorker to mount it on, the Thermo Quad on that 440 was so full of emission junk it never had any power. The 1411 is up for grabs. Anyone wants one pm me.
Re: 440 - Eddy 750 - Done. I am happy with result [Re: gdonovan] #1611444
05/06/14 02:33 PM
05/06/14 02:33 PM
Copper Dart Offline
Copper Dart  Offline
I don't have much experience with Eddelbrock Carbs.
Right out of the box the idle mixture was very easy to adjust. It starts right up, hot and cold, and has a very stable idle. My MAIN complaint is the severe bog when opening the secondaries. It may be that a stock '68 383 doesn't breathe enough to get the secondary fuel moving on a #1407 and adding a very tight converter (1100 RPM Stall it seems) to the mix equals a BOG condition with no realistic fix.
I'm hoping that with an AVS (Adjustable Valve Secondaries) I may overcome the BOG issues to a tolerable state until a better converter can be installed.
P.S. i did install the Mancini Racing Mopar Performance Electronic Ignition upgrade that netted little change on the Bog issue.
Mom.
Ricky Valdes
Re: 440 - Eddy 750 - Done. I am happy with result [Re: Silver70] #1611445
05/06/14 03:24 PM
05/06/14 03:24 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
413 with a stock/mild cam?
Re: 440 - Eddy 750 - Done. I am happy with result [Re: Pynzo] #1611446
05/06/14 03:30 PM
05/06/14 03:30 PM
minnesota
P
president61 Offline
president61  Offline
P
minnesota
I set up an Edelbrock 1405 (.089 primary,65-52rods,7 lb. springs,.095secondary, .028 pump jet)and 1411 (.101 primary, 70-47 rods, .089 secondary, .035 pump jet) to see which would work best for my situation. I used the jetting/rod combos from the original AVS' and had a little trouble dialing in the 1411 so switched to the 1405 with a ported wood spacer(Edelbrock 8723) and am very happy with the results. Plenty of low end power and torque which the 1411 wouldn't deliver on my 383. Wish I still had my '73 New Yorker to mount it on, the Thermo Quad on that 440 was so full of emission junk it never had any power. The 1411 is up for grabs. Anyone wants one pm me.
are you sure they had that much cfm (630 and 750?
Re: 440 - Eddy 750 - Done. I am happy with result [Re: Copper Dart] #1611447
05/06/14 03:36 PM
05/06/14 03:36 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Very realistic fix, don't even have to remove the carb from the car to repair. PM me and I'll go over the details.
Re: 440 - Eddy 750 - Done. I am happy with result [Re: gdonovan] #1611448
05/06/14 03:56 PM
05/06/14 03:56 PM
Georgia
Georgia
Awesome post!
