WHICH motor 4 the 38 Plymouth, 5.7 or 360, EFI or carb?
#161087
12/04/08 12:55 PM
12/04/08 12:55 PM
Posts: 9,857 Cambridge Idaho
RUMBLON
Cambridge Idaho
Hey gang, I need some advise on several levels.
I am building a 38 Plymouth business coupe. I am using a Mustang 2 front suspension style via Fatman.
Right now it has a late model 8 3/4 in it that was there when I bought it. Its going to be a full fendered rig as I have all the parts, fenders, grille that are near perfect.
I now need to decide on what motor. I would love a 5.7 HEMI but I hear thats an expensive endeavor due to the wiring harness, ect. I planned on finding a salvage vehicle and pulling the motor, trans, computer ect.
The car will have electric windows, after market air and creature comforts. I want this to be a driver that can run cross country.
So that said, I keep hearing that a nice 360 is a LOT cheaper in all respects???
Can anyone give me some details on both, costs, what is available in the way of wiring for both, ect.
I am no wiring expert and will have some help from a guy who is not a mopar guy, but understands EFI, ect.
I dont mind spending a few more bucks, 2-3K to get the 5.7. running, and going but cant aford an outrageous cost difference when I know a nice built newer 360 will do the job and give me a nice RUMBLE when running.
any suggestions or advise is greatly appreciated. The car will more than likley also use a rack and pinion style steering.
Re: WHICH motor 4 the 38 Plymouth, 5.7 or 360, EFI or carb?
[Re: RUMBLON]
#161089
12/04/08 02:10 PM
12/04/08 02:10 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
Dave, the most economical way would be a carbarated 360,then a small block stroker, then a efi 360 magnum then the 5.7-6.1 HEMI. I hope to someday have a 5.7 or 6.1 HEMI in something for my wife,either the 34 phaeton delivery or a 70 challenger. I think any of those would work well for a great cross country cruiser and reliable rod. at the fall fling there was a 5.7 crate HEMI comlete,new and ready to go for $2,800. OBO as more and more start showing up in the junkyards the prices will be coming down. its the wiring that has me holding back. Ron... I found this place that has harness' but I dont know how much the computer goes for? http://www.hotwireauto.com/?page=sales-dcxprice list: http://www.hotwireauto.com/?page=pricelist#HemiEDIT: found some more info it looks like the wiring harness is $995. and a NEW computer is $650.00 if that is all you need to get one of these up and running I guess that's not to bad
[Re: Mopar Ron]
#161090
12/04/08 02:48 PM
12/04/08 02:48 PM
RUMBLON
Cambridge Idaho
Ron, from that website is the following
5.7L Hemi with Standard Shift 5.7L Hemi with 545RFE Automatic 5.7L Hemi with 727 Automatic 5.7L Hemi with 500 or 518 Automatic 6.1L or 6.4L Hemi with Standard Shift 6.1L or 6.4L Hemi with 545 RFE Automatic 6.1L or 6.4L Hemi with 727 Automatic 6.1L or 6.4L Hemi with 500 or 518 Automatic 5.2L or 5.9L Magnum with Standard Shift 5.2L or 5.9L Magnum with Automatic Shift Viper with Standard Shift Viper with Automatic Shift
what trans combo is best for the 5.7 or 5.9?
any benefits or reservations for certain treans for a driver/
[Re: RUMBLON]
#161092
12/04/08 05:11 PM
12/04/08 05:11 PM
Posts: 1,392 Thayer, MO
bohmer2
Thayer, MO
I have a 5.7L block and heads that I am hoping to build into a 392, the block and heads were cheap the stroker kits are still killers at ~3000 for the piston, rods, and crank.
Anyway, I was leaning towards running the 518 I have for the joy of overdrive and a higher rear gear. A cruiser I would consider either a 518 or a 545rfe for the overdrive aspect.
