Re: Erratic tach readings...
[Re: Bdrainy]
#1610682
04/22/14 10:49 PM
04/22/14 10:49 PM
Posts: 532 Marion, Ohio USA
kab69440
Marion, Ohio USA
I don't know. When that happens in my Camaro, it's time to change the spark plugs. After that it works fine again.
Just because you're paranoid, it doesn't mean they are not out to get you.
WANT TO BUY- Looking for a CD by 'The Sub-Mersians' entitled "Raw Love Songs From my Garage To Your Bedroom". Also, any of the various surf-revival compilation albums this band has contributed to.
[Re: Bdrainy]
#1610684
04/23/14 05:36 PM
04/23/14 05:36 PM
RapidRobert
If you are disconnecting the wiring right at the tach & hooking up the new tach up right at that point & it's fine then that unfortunately pretty much confirms that it is downstream from the connections which only leaves the tach. Not sure why the green sense wire getting pinched fried it but it sounds like it has to come out. tho I would hook it up again outside the dash just to confirm before I spent the time/money to send it in
[Re: Bdrainy]
#1610685
04/24/14 11:20 AM
04/24/14 11:20 AM
Posts: 1,822 Colorado
denfireguy
Colorado
I'm not talking slightly off readings...it's bouncing from 1000rpm up to 4000-5000rpm..
I know the wiring is good as I can hook up another after market tach that I have it works/reads fine. The problem points to the tach...but I just can't believe shorting out the lead wire would fry it like that...
Unfortunately, it has to be the tach and it was probably a coincidence. The only way I could see that happening would be from a bad design and I think they have they have tach designs pretty well figured out by now. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
