New power steering box pulls to one side? Help!
#1610465
04/21/14 11:18 PM
04/21/14 11:18 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
During an overhaul of my engine bay I put in a re-manufactured power steering gear box to replace the loose and leaky original. When I started it up and ran new fluid through the system I noticed that my wheels locked all the way to the left. Turned the steering wheel side to side and it steers very rapidly back to the left. Does the same with the wheels in the air or on the ground on gravel. I don't want my shake down trip with the new engine to end in me driving into an oncoming semi. Is there an adjustment somewhere I don't know about to correct this? It doesn't pull hard, like it is fighting me, but it would sure steer me into a hard left if I let go of the steering wheel for a second. If there is an adjustment, pictures would be awesome!
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: New power steering box pulls to one side? Help!
[Re: Challenger 1]
#1610467
04/21/14 11:42 PM
04/21/14 11:42 PM
Posts: 1,357 central Florida
VL21
central Florida
Put jackstands under the control arms, no weight on the tires, just tap it back and forth til it doesn't pull. It won't move much, and it doesn't take much. Just barely loosen the bolts. Good pic
It takes gasoline to interest me.
[Re: Twostick]
#1610470
04/23/14 11:57 AM
04/23/14 11:57 AM
Michael Ecks
Columbus, GA
Thanks guys, worked like a charm. Probably the easiest thing I've done on the car in years. Glad I only had a slight pull, sounds like some people have had real nightmares starting up with their arm through the steering wheel.
For future readers, I had to tap the valve toward the rear of the car to correct steering to the left. Not sure if it is a rule or just how mine was acting.
[Re: Michael Ecks]
#1610471
04/23/14 01:51 PM
04/23/14 01:51 PM
Posts: 3,344 Central TX
roe
Central TX
Off topic but sweet ride. It looks good with the wheel and tire combo. What are they?
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: Rustydog]
#1610473
04/23/14 04:31 PM
04/23/14 04:31 PM
Michael Ecks
Columbus, GA
Thanks guys. They are from the discontinued Z Racing line way back in the 90s as said, got a steal on them when I worked at Western Auto (Sears). I liked them because they looked modern but not too flashy which is why I got the silver instead of chrome. I only see a couple sets a year, usually on old jeeps and trucks. Don't think I have ever seen another set on a car. I keep my eyes open for another set to have powdercoated in graphite or another dark shade, but they just aren't out there like some other wheels.
cheers
[Re: Rustydog]
#1610475
04/24/14 06:56 PM
04/24/14 06:56 PM
roe
Central TX
You guys have any side profiles of your car with those wheels on? Did they ever make them with the 5x5.5 wheel pattern? I was planning on 20" steelies all around on my truck, but those would look great instead.
