70 'cuda ball joint replacement #1609198
04/18/14 11:47 PM
04/18/14 11:47 PM
North Pole,New York
formula_s Offline OP
North Pole,New York
So I go to replace the uppers today and after I get the cotter pin out of the castellated nut both the nut and the ball joint stud are turning.How do I get the nut off with minimal bloody knuckles and swearing?
Re: 70 'cuda ball joint replacement [Re: formula_s] #1609199
04/18/14 11:57 PM
04/18/14 11:57 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Drive a pickle fork in there to wedge it while undoing the nut, or just whizz wheel the nut and stud end off
Re: 70 'cuda ball joint replacement [Re: DAYCLONA] #1609200
04/19/14 12:01 AM
04/19/14 12:01 AM
Kirkland, Washington
Pacnorthcuda Offline
Or gently tighten the nut then loosen again. You can often stop the turning of the ball joint by doing that, then remove the nut and knock the joint back apart.
Re: 70 'cuda ball joint replacement [Re: Pacnorthcuda] #1609201
04/19/14 12:24 AM
04/19/14 12:24 AM
North Pole,New York
North Pole,New York
Those are all good ideas. It's cold and dark now so I'll try it in the morning.
Re: 70 'cuda ball joint replacement [Re: formula_s] #1609202
04/20/14 01:01 AM
04/20/14 01:01 AM
North Pole,New York
North Pole,New York
Tried jamming the fork in there, only made the nut harder to turn and the stud kept spinning with it. Had to cut the nut off with a Dremmel . Why do I keep working on these 40+ year old Cars???
