Master cylinder alternative #1609194
04/18/14 11:34 PM
04/18/14 11:34 PM
Kentucky
dfsmopars Offline OP
Kentucky
What is a good alternative to a factory master cylinder? Maybe it's just the reman units I have bought but the last two I've had leak out underneath the lid.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Master cylinder alternative [Re: dfsmopars] #1609195
04/19/14 01:10 AM
04/19/14 01:10 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Strange as it may sound I fought this issue several years back and Long story short, found that by tightening the spring latch (bending it) on the lid the problem went away
hope this helps
Re: Master cylinder alternative [Re: TJP] #1609196
04/20/14 12:52 AM
04/20/14 12:52 AM
Kentucky
Kentucky
hope this helps
Did that with no success. Went today and just ordered a NEW Wagoner unit. Hopefully NEW is where it's at.
It just seems I've had my share of troubles over the years with Mopar master cylinders.
Re: Master cylinder alternative [Re: dfsmopars] #1609197
04/20/14 01:55 AM
04/20/14 01:55 AM
While you are waiting for it you might check that the MC perimeter and the lid & both sides of the gasket are clean/smooth/no tears/good contact. You might lower the fluid level slightly as it dont need to be all the way up near the top. that topping off is for your average Joe that might not check the level regularly like we enthusiasts do. The fluid would need to be very very low to be in danger of causing no pressure. Most levels are way higher than what is needed for a safety margin & that's not a problem as most dont leak
