Page 1 of 3 1 2 3
tunnel ram vs. single plane #1608960
04/18/14 12:50 PM
04/18/14 12:50 PM
Saskatchewan (SK)
79410aspenrt Offline OP
Saskatchewan (SK)
my 440 w2 small block currently has a holley pro dominator tunnel ram with 2-650 holleys. I have a holley strip dominator single plane with a 950 pro systems that I would like to try.
will I lose any power switching to the single plane
Re: tunnel ram vs. single plane [Re: 79410aspenrt] #1608961
04/18/14 12:55 PM
04/18/14 12:55 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Yes
Re: tunnel ram vs. single plane [Re: GTX MATT] #1608962
04/18/14 01:34 PM
04/18/14 01:34 PM
Locomotion Offline
Locomotion  Offline
.....but it will be earier to tune, especially if you footbrake and off the line in general.
Re: tunnel ram vs. single plane [Re: Locomotion] #1608963
04/18/14 02:04 PM
04/18/14 02:04 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Old wives tale, tunnel rams are not hard to tune, you just have to think a little different.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: tunnel ram vs. single plane [Re: Slingshot383] #1608964
04/18/14 02:18 PM
04/18/14 02:18 PM
Guitar Jones Offline
I totally agree. My TR is actually easier to drive, stage, foot brake or trans brake. I have two BG 750's on my 408 and I'm sorry I didn't get the 850's now.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: tunnel ram vs. single plane [Re: 79410aspenrt] #1608965
04/18/14 03:01 PM
04/18/14 03:01 PM
AndyF Offline
AndyF  Offline
I think that is a good tunnel ram so you will probably be hard pressed to beat the power with a single plane intake. But I've run more than few dyno tests where the tunnel ram is a dog. Some of the old school tunnel rams are very weak when compared to a good single plane intake.
Re: tunnel ram vs. single plane [Re: AndyF] #1608966
04/18/14 03:08 PM
04/18/14 03:08 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
My old Weiand Tunnel Ram was 40hp better than an Indy single plane with a 1140 dominator.Dave
Re: tunnel ram vs. single plane [Re: quickd100] #1608967
04/18/14 07:22 PM
04/18/14 07:22 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My old 9 second Dartsport was quicker with a tunnel ram and was deadly consistent footbraking.
Re: tunnel ram vs. single plane [Re: ProSport] #1608968
04/18/14 07:25 PM
04/18/14 07:25 PM
I have always had good luck with big block tunnel rams--always a big MPH jump in the 1/4 mile
Stay Away from and never use a single 4 TR--the end cylinders go crazy lean.
Re: tunnel ram vs. single plane [Re: ] #1608969
04/18/14 08:06 PM
04/18/14 08:06 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I'm hoping to go the other way
Re: tunnel ram vs. single plane [Re: roadhazard] #1608970
04/18/14 09:12 PM
04/18/14 09:12 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I have one for my W2 but sadly if I do the 440 in the 66 Val wagon now I doubt I'll get to use it....I'd like to trade it for a standard port TR since a tr set up will actually fit under the Rocky's hood
WIZE
In Car:
Re: tunnel ram vs. single plane [Re: 79410aspenrt] #1608971
04/19/14 12:58 PM
04/19/14 12:58 PM
Earth
Rob C Offline
Rob C  Offline
Earth
That is a really good intake. Very old. Take the time to jet and set it up. There is a lot more labor in that set up. IF the engine is a stout one that can take advantage of such an induction system, you'll go faster.
Re: tunnel ram vs. single plane [Re: Rob C] #1608972
04/19/14 01:10 PM
04/19/14 01:10 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
RobC, which intake are you referring to?
Re: tunnel ram vs. single plane [Re: Rob C] #1608973
04/19/14 01:18 PM
04/19/14 01:18 PM
Saskatchewan (SK)
Saskatchewan (SK)
I assume your talking about the tunnel ram? I did dyno tune the tunnel ram, ended up getting 652 hp and 590 tq.
I think my engine is stout enough for the tunnel ram. 440'', 660 roller, 13.1 comp.......
Re: tunnel ram vs. single plane [Re: 79410aspenrt] #1608974
04/19/14 02:31 PM
04/19/14 02:31 PM
One tip I can give you is don't use any power valves.
Re: tunnel ram vs. single plane [Re: Guitar Jones] #1608975
04/19/14 09:42 PM
04/19/14 09:42 PM
crisfield, maryland 21817
8
82ramIndy493 Offline
What factors about the way the engine is built decide if a tunnel ram is a better choice over a single plane intake and one 4 bb carb? I have a 493 at 12 to 1 comp with OOTB Indy SR's with a comp 262 575 with 1.6 rockers, plenum ported Victor intake and 1050 Dominator. Would this engine benifit from a TR?
Re: tunnel ram vs. single plane [Re: 82ramIndy493] #1608976
04/20/14 12:01 AM
04/20/14 12:01 AM
gregsdart Offline
gregsdart  Offline
Tunnel rams are able to be ram tuned better for the rpm range usually, due to the extra runner length. I believe that is the main advantage, along with usually less restriction at WOT. There is always an exception(G3 Hemi?) though to any rule, or so it would seem.
Re: tunnel ram vs. single plane [Re: gregsdart] #1608977
04/20/14 12:30 AM
04/20/14 12:30 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
511ci
13.1 comp 277/800 roller indy cnc345s
indy-2 adapter 1050 ------ 9.91
indy tunnelram two 750s ------9.85
went two times got sent home ------ no tuning
1.39 9.85 - 137 mph
Re: tunnel ram vs. single plane [Re: ProSport] #1608978
04/20/14 12:20 PM
04/20/14 12:20 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Pro sport - 79410
Sorry guys, yes, the Holley. My bad.
Honestly no personal experience with it. Just from what friends have run. I myself just picked up a never used M1-Tunnel Ram. Runners are shorter with more plenum.
Re: tunnel ram vs. single plane [Re: 82ramIndy493] #1608979
04/20/14 05:28 PM
04/20/14 05:28 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I bet you'd be at least a tenth quicker with a tunnel ram and the right carbs. Carbs are key, I ran two 750 Quickfuel tunnel ram carbs and they were perfection right out of the box.
Page 1 of 3 1 2 3
