tunnel ram vs. single plane
#1608960
04/18/14 12:50 PM
04/18/14 12:50 PM
Posts: 251 Saskatchewan (SK)
79410aspenrt
Saskatchewan (SK)
my 440 w2 small block currently has a holley pro dominator tunnel ram with 2-650 holleys. I have a holley strip dominator single plane with a 950 pro systems that I would like to try.
will I lose any power switching to the single plane
Re: tunnel ram vs. single plane
[Re: Locomotion]
#1608963
04/18/14 02:04 PM
04/18/14 02:04 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Old wives tale, tunnel rams are not hard to tune, you just have to think a little different.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Slingshot383]
#1608964
04/18/14 02:18 PM
04/18/14 02:18 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
I totally agree. My TR is actually easier to drive, stage, foot brake or trans brake. I have two BG 750's on my 408 and I'm sorry I didn't get the 850's now.
[Re: ProSport]
#1608968
04/18/14 07:25 PM
04/18/14 07:25 PM
I have always had good luck with big block tunnel rams--always a big MPH jump in the 1/4 mile
Stay Away from and never use a single 4 TR--the end cylinders go crazy lean.
[Re: Rob C]
#1608972
04/19/14 01:10 PM
04/19/14 01:10 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
That is a really good intake. Very old. Take the time to jet and set it up. There is a lot more labor in that set up. IF the engine is a stout one that can take advantage of such an induction system, you'll go faster.
RobC, which intake are you referring to?
[Re: 79410aspenrt]
#1608974
04/19/14 02:31 PM
04/19/14 02:31 PM
Guitar Jones
One tip I can give you is don't use any power valves.
[Re: 82ramIndy493]
#1608976
04/20/14 12:01 AM
04/20/14 12:01 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Tunnel rams are able to be ram tuned better for the rpm range usually, due to the extra runner length. I believe that is the main advantage, along with usually less restriction at WOT. There is always an exception(G3 Hemi?) though to any rule, or so it would seem.
[Re: gregsdart]
#1608977
04/20/14 12:30 AM
04/20/14 12:30 AM
Posts: 5,618 long island NY
Ari440
long island NY
511ci 13.1 comp 277/800 roller indy cnc345s indy-2 adapter 1050 ------ 9.91 indy tunnelram two 750s ------9.85 went two times got sent home ------ no tuning
1.39 9.85 - 137 mph
[Re: 82ramIndy493]
#1608979
04/20/14 05:28 PM
04/20/14 05:28 PM
ProSport
Akron, Ohio
What factors about the way the engine is built decide if a tunnel ram is a better choice over a single plane intake and one 4 bb carb? I have a 493 at 12 to 1 comp with OOTB Indy SR's with a comp 262 575 with 1.6 rockers, plenum ported Victor intake and 1050 Dominator. Would this engine benifit from a TR?
I bet you'd be at least a tenth quicker with a tunnel ram and the right carbs. Carbs are key, I ran two 750 Quickfuel tunnel ram carbs and they were perfection right out of the box.
