Way to test temp gauge/sender? 70 B Body? #160870
12/03/08 08:20 PM
12/03/08 08:20 PM
USA
Suregrip391 Offline OP
USA
Is there a simple way to test the water temp gauge without taking the dash apart? It's in a 70 Satellite. Not sure if my problem is in the gauge, wiring, or the sender? Hoping there is a simple test out there similar to the way you test a fuel gauge, by grounding the wire and watching for the gauge deflection... Anything?
Re: Way to test temp gauge/sender? 70 B Body? [Re: Suregrip391] #160871
12/03/08 08:27 PM
12/03/08 08:27 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Same thing, ground the wire, but you should be using a 10 ohm resistor in the circut as that should give a full hot reading, just grounding the sender wire should bury the needle & can burn out the gauge...I seem to recall 73 ohms is the cold reading spec...
Re: Way to test temp gauge/sender? 70 B Body? [Re: 1_WILD_RT] #160872
12/03/08 08:52 PM
12/03/08 08:52 PM
USA
USA
Cool, thanks! Even if touching it for a split second, will that blow the gauge? Probably not worth that gamble, huh?.....I dont have any resistors.
Re: Way to test temp gauge/sender? 70 B Body? [Re: Suregrip391] #160873
12/03/08 09:12 PM
12/03/08 09:12 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
You could just ground it and then with you watching the gauge turn the key on a see if the gauge rises then shut the key off as soon as it goes above 3/4 of the way up. It won't blow the gauge unless you let it go all the way to hot and leave it there.
Re: Way to test temp gauge/sender? 70 B Body? [Re: stumpy] #160874
12/03/08 09:19 PM
12/03/08 09:19 PM
USA
USA
SOunds good, thanks..I will give it a shot tomorrow after work. Appreciate it guys!
Re: Way to test temp gauge/sender? 70 B Body? [Re: stumpy] #160875
12/03/08 09:33 PM
12/03/08 09:33 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yeah it's letting the gauge stay buried that burns it out, passing more current than it's designed for...
