Sparta Small Tire Shootout 2014 #1607942
04/15/14 09:10 PM
04/15/14 09:10 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Hope this is in the right section...
Check out our most updated Event flyer for the Sparta Small Tire Shootout!!
The racers spoke and we listened!!!
Let us know if you plan to come out for sure to help us get an idea of car count!!
If you have any questions, you can ask them on here or to SSTS staff privately through our contact info.
http://smalltireracing.wix.com/ssts2014
Re: Sparta Small Tire Shootout 2014 [Re: mshred] #1607943
04/15/14 10:44 PM
04/15/14 10:44 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Good luck Matt, hope it turns out great
Re: Sparta Small Tire Shootout 2014 [Re: SpareParts] #1607944
04/15/14 10:47 PM
04/15/14 10:47 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Thanks Dylan! About the only thing I am looking forward to right now after the recent b.s. with my own car
Re: Sparta Small Tire Shootout 2014 [Re: mshred] #1607945
04/15/14 11:20 PM
04/15/14 11:20 PM
BPE Offline
BPE  Offline
Hope you have a good turn out.
Rod
Re: Sparta Small Tire Shootout 2014 [Re: BPE] #1607946
04/16/14 11:56 AM
04/16/14 11:56 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
hope you get your car done in time.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Sparta Small Tire Shootout 2014 [Re: 1967dartgt] #1607947
04/16/14 09:16 PM
04/16/14 09:16 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Me too. I am curious how much you pick up with the 360-2 heads. I am also running those heads.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Sparta Small Tire Shootout 2014 [Re: D-50] #1607948
04/16/14 09:19 PM
04/16/14 09:19 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Thanks fellas!
I hope I get it done in time too...Going to yank the motor out this Friday, and try and bang out everything I need to do to it on saturday.
Not sure how much I will pick up with the new heads and solid roller...I am putting in a tighter nitrous converter, so it might be hard to gauge properly, but I am still hoping to break into the 10's on motor with the new converter and then spray it to some new personal bests
I would really like to have it done by the event so I can get some grudge action with the car
