800$ cut to 400#$ score of the day
#1607433
04/14/14 04:17 PM
04/14/14 04:17 PM
Posts: 15,487 Florida
scratchnfotraction
picked this 88 swb truck up for 800$ got it home and sold the hood and 2 fenders/2 doors for 400$ couple hrs later. clean title,slight rust on drip rail roof corner but solid elsewhere, has had the headlights moved to a 2 wat toggle switch on the dash. aftermarket a/c added under dash with non-a/c airbox. has had the pcm removed and a ecu/dist wired in along with the older VR/plug at the fender where the pcm should be. has a pre-roller cam 318 with a mech fuel pump. I will be looking that wireharness over real good to see what is up with it...? not sure if it has been opend and some removed or what. I don't see any plugs for tbi stuff?? I noticed it has the small 5 on 4.5 wbp ?? has a 9 1/4 rear so I am needing to take time to get to know this ol girl here..seems she has been worked on a little. I will be converting the front end to 4x4 leafs for a gasser truck build on whats left as my next project.
Re: 800$ cut to 400#$ score of the day
[Re: 340SHORTY]
#1607440
04/14/14 08:53 PM
04/14/14 08:53 PM
Posts: 5,964 Greenville, PA
redraptor
Greenville, PA
Im begining to not like you.
Can't imagine a rebody or reframe but who knows. Congrats on your karma find.
[Re: Hemi_Ram]
#1607441
04/14/14 09:37 PM
04/14/14 09:37 PM
scratchnfotraction
Good deal Mike, so are you just going to part this out or??? You cant find them that cheap up here without having rusted floors and boxes.
well I was able to have someone else buy it for the 800 and take the hood doors fenders for 400 leaving me to pay 100 every 2 weeks on the other 400.
I don't need it or really want it but it was just to nice to pass up.. so I figure what the hell..use it for parts/scrap the rest...sit on it as a running 3/4 of a truck that would fix right back up...or make it the gasser project I want to do(which I rather have a 4x4 frame to start with) but..? got what I got to start I guess.
not sure when I would get another this cheap or this good of shape around here in central Fl.
[Re: NITROUSN]
#1607443
04/15/14 03:21 AM
04/15/14 03:21 AM
Posts: 3,344 Central TX
roe
Central TX
Very nice. Looks like it would have a made a really nice/fun driver if it had stayed together. Do you already have the stuff to replace the doors, etc...?
roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: NITROUSN]
#1607444
04/15/14 10:38 AM
04/15/14 10:38 AM
scratchnfotraction
Not that it matters but 88 should be fuel injected unless it was a 360 4 barrel.
correct. looks to have been converted to mech pump.. it does have the tbi fuel lines down driver side of frame.
it has also been converted to a ecu/dist and the PCM on fender is gone. has the VR added on as well. runs ok and had no issuse as a driver. it has just been parked for 10 months now.
the 9 1/4 must have been put under it as it is small bolt pattern with the front rotors swaped to small bolt pattern with it.
must have been some kind of mopar mechanic that worked on it from the looks
the add on a/c has the lines thru firewall by the brake booster.
[Re: Golden-Arm]
#1607448
04/16/14 05:22 PM
04/16/14 05:22 PM
scratchnfotraction
sweet score scratch. i cruise around here on my days off, but all i see is rotted out garbage. the best stuff seems to come from west texas, new mexico, arizona and nevada. if you want to make a quick hunert, i'll give ya five for it.....
it wont have a hood/fenders/doors but you can come get it for 500$ I will get the hood/fenders/doors that they replace..which have just been painted a metalic gun metal grey. ACE on the gun again.
they were ready to go to the scraper for 300$ when I worked out a deal to save it for parts if nothing else.
no matter to me..I am stripping it down to the frame to start a build if it does not go as a whole truck fast. plenty-O-parts on it
whats up Goose? long time no see.
[Re: Webster]
#1607450
04/17/14 06:59 PM
04/17/14 06:59 PM
Posts: 256 libby mt
lifted85
libby mt
a gasser build sweeet!! i have always had the idea of buildin a ramcharger/gasser.. cant wait to see how this turn's out man
drive fast, drive hard, DRIVE MOPAR
[Re: scratchnfotraction]
#1607452
04/17/14 11:43 PM
04/17/14 11:43 PM
scratchnfotraction
but this is the look I want but just in a mid 80s macho truck paint job with drag skinnys/fattys for a street brute.
does not have to do much other than a burn out and look good cruzing without breaking down.
