cowl guage pac #1607394
04/14/14 04:05 PM
04/14/14 04:05 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I made this to get some ideas on making the cluster look better while trying to keep busy.
I don't want to have the cups on the backs so if you have any ideas LMK.Yes I will paint it.
Re: cowl guage pac [Re: Clanton] #1607395
04/14/14 07:42 PM
04/14/14 07:42 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Will you be able to read them with the glare?
I just made this to hold my extra gauges...painted it black of course
Not directly in site, but good enough I feel
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: cowl guage pac [Re: Clanton] #1607396
04/14/14 09:16 PM
04/14/14 09:16 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
mine are under the cowl...have since added a shift light
https://www.youtube.com/watch?v=XoCaHhiqShI
Coming soon!!!!
Re: cowl guage pac [Re: OUTLAWD] #1607397
04/14/14 09:36 PM
04/14/14 09:36 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have an overhange but wont be able to tell untell I get in the sun in the drive but a 1.5" should work to block light.
Re: cowl guage pac [Re: Clanton] #1607398
04/14/14 10:44 PM
04/14/14 10:44 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I need to figure out how to mount it yet!I can trace and make a base plate to prevent scratching if it moves but it need to be mounted to the grates where you see it.The hood is not an option with coiled tubes under it near the headers that are high in the engine bay.Thanks for any help!I could bend an L and screw it to the side of the pac with the L going under the grates.
Re: cowl guage pac [Re: Clanton] #1607399
04/16/14 11:05 AM
04/16/14 11:05 AM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
Mike
All you need on top would be feul press and boost press gauges. The rest would be in the car. If i had kept my roots i'd have mounted the 2 gauges with a bracket off the back of the blower angled a bit towards the driver. I have the 2 gauges in cups directly in front of me for the procharger set up.It would be less of a visibility restriction and a little cleaner look.Just my
Re: cowl guage pac [Re: Blown 68 R/T] #1607400
04/17/14 10:33 AM
04/17/14 10:33 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Different strokes for different folks
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: cowl guage pac [Re: hemi-itis] #1607401
04/17/14 10:45 AM
04/17/14 10:45 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
dam how do you eyeball all those guages and drive the car down the track? You got them googley eyes like a Chameleon?
Re: cowl guage pac [Re: Mr.Yuck] #1607402
04/17/14 10:57 AM
04/17/14 10:57 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I use a cam corder,not that I have that many.
Re: cowl guage pac [Re: Mr.Yuck] #1607403
04/17/14 11:16 AM
04/17/14 11:16 AM
hemi-itis Offline
hemi-itis  Offline
Realality,,,,,,,,,I can't see even the tach when the pedal hits the floor.It's a handful!! I'm installing a shift light along with the racepak
Re: cowl guage pac [Re: hemi-itis] #1607404
04/17/14 11:36 AM
04/17/14 11:36 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I hope we both can get out and make use of our datas however it is collected!
Re: cowl guage pac [Re: Blown 68 R/T] #1607405
04/17/14 11:40 AM
04/17/14 11:40 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Mike
Thanks for the tips!I may change things a time or two so it is good to have options.
Re: cowl guage pac [Re: Clanton] #1607406
04/17/14 11:43 AM
04/17/14 11:43 AM
hemi-itis Offline
hemi-itis  Offline
I got to go to a car show last Sunday,no bumpers,,,,,,,,,but who cares I was cruzin
Re: cowl guage pac [Re: hemi-itis] #1607407
04/17/14 12:08 PM
04/17/14 12:08 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
heres the one I made for my old 67 S/C'd coronet. yes it's made from a think black plastic paint roller pan. The dark gauge is a digital a/f meter.
Re: cowl guage pac [Re: Mr.Yuck] #1607408
04/17/14 12:08 PM
04/17/14 12:08 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
one more.
Re: cowl guage pac [Re: Mr.Yuck] #1607409
04/17/14 12:30 PM
04/17/14 12:30 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Hemiitis congrats on getting out early!
MR Yuck I can appreciate your use of available materials!
Re: cowl guage pac [Re: Clanton] #1607410
04/17/14 12:33 PM
04/17/14 12:33 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
feel free to use anything you see. It's also attach by velcro, I didn't want to dril into my perfect dash
Re: cowl guage pac [Re: Mr.Yuck] #1607411
04/17/14 12:36 PM
04/17/14 12:36 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I feel the same about my dash so what did you do run the wires,tube up the side and over?I dont think my mech temp gauge will go that far but it is a option.
Re: cowl guage pac [Re: Clanton] #1607412
04/17/14 12:57 PM
04/17/14 12:57 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yes up the side all tucked away. My temp and oil pressure were mounted below the dash as usual. Those were just the gauges I added for the boost. The Fuel pressure is electric. The sending unit was mounted on the fuel line by the carb. (see pix)
Re: cowl guage pac [Re: Mr.Yuck] #1607413
04/17/14 01:13 PM
04/17/14 01:13 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I had an electric FP and did not like it.I would keep all the gauges I have to be sure all is working well and then reduce the number.
