Leaking '70 repop disc brake metering valve
#1607067
04/13/14 11:54 PM
04/13/14 11:54 PM
Posts: 368 Jacksonville, Fl
426runner
Jacksonville, Fl
There are plenty of accounts online of the repop metering valves leaking. My first one from Inline Tubes leaked so they sent me another one. The second leaked ever so slightly so I stuck with it. Now as I actually drive and brake, the thing leaks REAL bad under pressure from the pedal. I removed it and took it apart to find a very poorly made seal. From my readings online this seal cannot be bought separately.
Am I faced with continuing to get replacements until I receive one that doesn't leak? Has this bad part/leaking been resolved in the last couple of years and I missed it?
I understand that this valve delays the front discs for a split second when the pedal is applied. Can this thing be "gutted" and plugged, removing the "delay" and not adversely affect the braking?
Later, Sandy
'70 HEMI Road Runner B5/B5, 4 spd
"Sandy's Garage" on Facebook
Re: Leaking '70 repop disc brake metering valve
[Re: 426runner]
#1607072
04/14/14 03:03 PM
04/14/14 03:03 PM
426runner
Jacksonville, Fl
I called Fine Lines. They had them in stock. They tell me that the internal parts are from china HOWEVER, most sellers have the units assembled in China. That's where the issues are. Fine Lines receives the parts and assembles the units themselves, weeding out bad seals and assuring that the valves are assembled correctly. I took his word for it and ordered one. I'll let you know.
Later, Sandy
[Re: 426runner]
#1607073
04/14/14 09:07 PM
04/14/14 09:07 PM
Posts: 601 Mass
charge70
Mass
I got mine from Jamie at Mega Parts,No problems.Not sure who they buy from though. John.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: 426runner]
#1607076
04/15/14 01:14 PM
04/15/14 01:14 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I thought that I was the only one. My new valve leaks from the hex head plug at the end. I can't tighten it any tighter and I was going to pull it this week to see if I can add a seal. I don't recall which company supplied it though.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#1607077
04/15/14 02:20 PM
04/15/14 02:20 PM
Posts: 4,567 Motor City
6PKRTSE
Motor City
Yep, my re-pop leaked also. Sent it back. Received the second one. It leaked also. Tigtened the crap out of it & put teflon tape on the threads & has been trouble free for 3 years or so now.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#1607078
04/15/14 03:52 PM
04/15/14 03:52 PM
YO7_A66
Indiana
If the valve is on the car, how much fluid will leak out when I remove the hex head plug (facing towards the ground on the car)? Will I need to re-bleed the brakes? I want to try the teflon tape idea. Thanks
[Re: YO7_A66]
#1607079
04/15/14 07:19 PM
04/15/14 07:19 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Yes you will have to bleed the brakes... I have used teflon tape on them in the past and worked great for me
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1607080
04/15/14 10:08 PM
04/15/14 10:08 PM
YO7_A66
Indiana
I pulled the valve block out of the car and that plug was very tight. So I pulled both the bottomplug and the top fitting and added teflon tape to both male fittings. I will have it back on and will be driving the car this weekend to test it again. Thanks
[Re: YO7_A66]
#1607081
04/16/14 08:05 AM
04/16/14 08:05 AM
Posts: 322 MERRILLVILLE, INDIANA
sunroof446
I have had at least 3 that have leaked so far. Everyone I have bought so far has been assembled and never tightened up.You would think they would be a little more critical with brake parts but what do they know about making brake parts where they are made. They ride bicycles.This has been a ongoing problem for at least 3 years. I would keep sending them back until you get one that does not leak. If they are going to sell you junk parts that they know have a problem. I would make there job difficult and make sure they loose there profit in shipping cost. They don't care about your labor.
