cheap 318 build.. need some pointer's
#1606653
04/13/14 04:41 AM
04/13/14 04:41 AM
Posts: 256 libby mt
lifted85
libby mt
hey guy's, well last year i drove the d150 with the mostly stock 318 beside's the normal bolt on's ( long tube header's, performer intake, 600cfm carb) i want a little more giddy up & go. so im getting a comps XE256H cam (thanks to a member here) I dont want to yank the motor & do a complete rebuild but what else could be done to get a little more power?? i am swapping to 355 gear's which should help.. i am kickin around replacing the head's with a set from areoracing, i dont want to go throuw the hasle of the magnum head swap, i do got a pair of 89-90 tbi head's but last time i checked it was well over $500 to get them rebuilt.. any info would be great guy's
drive fast, drive hard, DRIVE MOPAR
Re: cheap 318 build.. need some pointer's
[Re: Kern Dog]
#1606655
04/13/14 07:07 AM
04/13/14 07:07 AM
Posts: 256 libby mt
lifted85
libby mt
truck is a 81 d150 2wd... i hate 360's so thats why opted for a 318.. truck has duel 2.5" exhaust along with long tube header's... i got a set of 308/302 head's but like i said the shop wanted well over $500 to just rebuild um.. the onse from areo heads are 1.88-1.60 IIRC
[Re: lifted85]
#1606656
04/13/14 07:47 AM
04/13/14 07:47 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Around here Magnum 5.2's are cheap, picked up my last one for $150
Consider swapping one in with a carb intake.
"I think its got a hemi"
[Re: lifted85]
#1606657
04/13/14 11:50 AM
04/13/14 11:50 AM
RapidRobert
I would reconsider the mags. JY ones are cheap & you'd just need a mag compatible intake & possibly different pushrods. If you're dead set against them then the 302's with some home porting. You desperately need compression which the closed chambered mags/ 302's would provide. A cam from Hughes and alot of time tweaking the dist subsytems in order: initial/total to 35 (31 if mags)/springs/vac adv. May I ask why you dislike 360's? as you desperately need torque (more cubes) for your app.
[Re: RapidRobert]
#1606658
04/13/14 12:13 PM
04/13/14 12:13 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
I would like to know why you would pass on the 360 too? Big mistake in my opinion.
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#1606659
04/13/14 06:46 PM
04/13/14 06:46 PM
Posts: 256 libby mt
lifted85
libby mt
spent a fortune a 360 i had built & it was a dog. every 318 i have owned has been good.. like i said i got my mind set on the comp XE256H dont want to go through spending a fortune on a new intake, push rod's, lifters with the mag head swap.. looks like i will pick up a set of areo & do a little porting & call it good....
[Re: lifted85]
#1606660
04/13/14 08:57 PM
04/13/14 08:57 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
You do know that the 302 and 308 are totally differnt castings, right? The 360 was a dog? If you build a 318 and a 360 with identical specs, the 42 extra cubic inches will always win.
[Re: Kern Dog]
#1606661
04/14/14 01:18 AM
04/14/14 01:18 AM
Posts: 256 libby mt
lifted85
libby mt
ya i know they are differnt lol... not a fan of 360s just me... would the #308s be worth rebuilding compared to the areo heads?
[Re: lifted85]
#1606662
04/14/14 01:29 AM
04/14/14 01:29 AM
RapidRobert
Aero heads are Indy's garden variety rebuilt heads & been a few bad reports on them tho probably not any more than anyone else (we're in the business of solving problems here on Moparts) so we get way more bad reports than good but they are open chambered. I would strongly consider finding some 302's (closed chambers) & open em up a bit. FYI 308's are the best of all the iron open chambered heads
[Re: RapidRobert]
#1606663
04/14/14 02:48 AM
04/14/14 02:48 AM
Posts: 256 libby mt
lifted85
libby mt
i will have to double check but im sure the head's i pulled of my 89-90 w150 318 was 308's.. might have to run to the next town & see what they will charge to rebuild um... whats the normal rate you buy's pay to get them rebuild
[Re: Kern Dog]
#1606665
04/14/14 10:25 AM
04/14/14 10:25 AM
Posts: 15,487 Florida
scratchnfotraction
Switching from 302s to 308s is a tradeoff. The 308s flow better but they also have larger chambers resulting in a 1/2 point loss in compression.
#308 is a 89-91 360 swirl port/open chamber head and is the best head since the X heads back in the day. they redid the exhaust port to flow more. they only came on a 360 TBI engine.
BUT>>in a JY they are few and pron to cracks same as the mag heads.
I agree with you Zack, 360 are not everyones cup of tea. if you do not build the rest of the truck with the parts to make the 360 work it is always a dog no matter what it is in.
the over the counter LA & mag heads are only 75$ more than my local machine shop can do them for..so for 75$ more I get NEW head castings complete ready to install.
hard to beat next day also. most all of mine are a 600$ rebuilt short block with a 600$ set of heads.
comes out to about the same as a long block over the counter..
300$ 91-318 JY engine with a 400$ roller cam is what I am reving now. runs killer in my 85 stepside 2x truck for 700$
[Re: gdonovan]
#1606667
04/14/14 12:41 PM
04/14/14 12:41 PM
scratchnfotraction
I had already suggested just dropping a magnum 5.2 in, they can be had for dirt cheap, carb intakes are easy to lay hands on and used roller cams are anything from $50-$150 and don't wear out.
Better heads, better cam setup, lower friction rings, win-win all the way around.
I have only had 2 brand new engines at 3500 each...over rated and where nothing but hassle to deal with... granted race engines do not like daily driver duty..
so been doing cheap JY freshin ups and run them as hard as they will go till they give up for daily drivers.
dirt cheap and roller cams are investments for the long run.
[Re: scratchnfotraction]
#1606668
04/14/14 01:01 PM
04/14/14 01:01 PM
dogdays
No 318 ever came with 308 heads, unless it was a factory mistake. If you have heads off a late model 318, they are 302s, or there was another head with different casting number but same heart-shaped combustion chambers.
The 302s I'm running right now are from a 120,000 mile Fifth Avenue and they were not "rebuilt". Guides were still in tolerance and the seats looked good. I did cut down the valveguides so I could run a bigger cam later, and added new valve stem seals and Crane 308 springs which will be okay if I ever get the roller 318 cam reground. Then I did a whole bunch of home porting. I installed them with Mr Gasket thin head gaskets. I'm still working out the carburetion, but on its first long trip it returned something over 21 mpg. If you are absolutely bucks-down, find that late-model Fifth Avenue and pirate the heads, or the whole engine if you can. My shortblock had no ridge and the crosshatch still visible in the cylinders. Bearings were OK, too.
R.
[Re: dvw]
#1606671
04/14/14 10:39 PM
04/14/14 10:39 PM
Posts: 256 libby mt
lifted85
libby mt
well after dropin ina couple thousand it was a dog.. thats just me... the head's are stamped 714 so iirc they are fast burn head's.. are the 714's any good??
