Organisol "look" and "texture" #1604125
04/06/14 09:57 PM
04/06/14 09:57 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang....
I know I may be opening up a can of worms here...
I am trying to detail the taillamp panel on my Daytona with a more appropriate OEM-correct look. The finish on the Daytona now is too glossy and smooth. I know it is supposed to have the Organisol paint to it. The paint job on the Daytona's nice, but with that said, is pretty old ( 1994 ). I don't have a spray gun or appropriate size air compressor. I bought a can of Organisol paint from Totally Auto and it is crap.. Now, the paint might be ok, but the spraying stinks.... Sprays for about 3 seconds and then stops. I'm sure it is a defect in the can that Totally Auto contracts out? Regardless, I'm leary of purchasing another can at $25.00. Is there any name brand paints out there that provides a satin/rough feel like Organisol, like BBQ paint or something?
Troy
Houston Mopar Connection Club
Re: Organisol "look" and "texture" [Re: hemi68charger] #1604126
04/06/14 10:08 PM
04/06/14 10:08 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Hey gang....
I have used their paints as well and have run into this issue as well. Change out the nozzles and you will be fine. Make sure you tip the can upside down and spray out the remaining paint so it doesn't clog on your next use. They usually pack an extra nozzle, did they?
I really like their product overall.....
Admiration For Multiple Carburetor Vehicles...
Re: Organisol "look" and "texture" [Re: Stewpar] #1604127
04/06/14 10:27 PM
04/06/14 10:27 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Black sprayable primer from Advance is a real close match color wise and not too bad on the texture side. What I don't know is how it will hold up to sunlight, I used on the behind the bumper area on my AAR, if was tough to tell where the organosol stopped and the primer started, been on for 6 months on so with out fade.
I tried to post a picture but it was too big, PM and I will send them to you.
Careful, your character's showing!
Re: Organisol "look" and "texture" [Re: Stewpar] #1604128
04/06/14 10:28 PM
04/06/14 10:28 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Yes they have great paint considering it's in a spray can but there are always nozzle problems.
They used to and still may give you extra nozzles with every can. The only real fix I ever had was using a Undercoat nozzle with their thick textured stuff.
Also you have to shake their can's (is that even legal?) longer than a normal spray can.
Beware much testing is needed because it will spray out like never before!!!!
Ron
Re: Organisol "look" and "texture" [Re: RJS] #1604129
04/06/14 11:27 PM
04/06/14 11:27 PM
Houston, Tx
Houston, Tx
Ron
Yeah Ron...
I value your judgement and experience. I shook the can for many many minutes. As you know from my posting here too, I've been doing this sort of thing for a long time, granted not at the professional level.
I changed out the nozzle with the new one that was provided with the can. Cleaned it out multiple times..... The nozzles are clean, it has to be the valve within the can the nozzles press into.... There are times when, if I hold it JUST right, the nozzle sprays continuously. But, with the panel, I need to be able to make a continuous spray pattern from one side to the next, then back and be consistent about it. Per the cans instruction, I need, for best results, apply two coats. I'm not here to bad-mouth Totally Auto, I just feel like I'm wasting my time. I once had a can from them years ago and it did the same thing. I don't know if there's a shelf life to these. I bough the can, oh,,,,,, about 9 months ago?
I'll call them tomorrow and see what they say..... I basically just threw $25 out the window...
Thanks for the input..
Troy
Re: Organisol "look" and "texture" [Re: Stewpar] #1604130
04/06/14 11:39 PM
04/06/14 11:39 PM
mopar346 Offline
mopar346  Offline
black sprayable primer from Advance is a real close match color wise and not too bad on the texture side. What I don't know is how it will hold up to sunlight, I used on the behind the bumper area on my AAR, if was tough to tell where the organosol stopped and the primer started, been on for 6 months on so with out fade.
Re: Organisol "look" and "texture" [Re: mopar346] #1604131
04/06/14 11:53 PM
04/06/14 11:53 PM
Houston, Tx
Houston, Tx
Has anyone heard of the Dutch Boy #3751 Black Satin? I believe it was mentioned once in the wwboa.org club?
Troy
Re: Organisol "look" and "texture" [Re: hemi68charger] #1604132
04/07/14 12:25 AM
04/07/14 12:25 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
.....Might want to try Mar-Hyde, spraying at some distance will give you more texture, of course the correct method is to have the proper spray equipment and product
Re: Organisol "look" and "texture" [Re: hemi68charger] #1604133
04/07/14 12:26 AM
04/07/14 12:26 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Yep I'm not bad mouthing their stuff either I used it over the years.
Butt... it really is hit or miss with their paint. Believe it or not I have some grill Argent from them for probably 15+ years that still works but only with the undercoat nozzle.
They will probably make it right for you.
Oh and never used or saw the Dutch Boy.
Maybe that Advance store primer will workout for you.
Ron
Re: Organisol "look" and "texture" [Re: hemi68charger] #1604134
04/07/14 01:15 AM
04/07/14 01:15 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
On a car that rare, I'd buy the Organisol from Frank Badalson & have someone load it in their gun & shoot it for you. That's what I did for my Challenger & it looked great & held up great. You can prep it & mask
it to save some bucks. IMO, its better than having to redo it because clogged up spray nozzles left it clumpy & splotchy on your Daytona.
Re: Organisol "look" and "texture" [Re: Triggerfish] #1604135
04/07/14 05:29 PM
04/07/14 05:29 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Troy, I know it sounds crazy, but for $7 try spraying this stuff and see what you think. I was kinda shocked at how it turns out. Sprays nice, durable, dries to a low gloss sheen and you can experiment with the distance to achieve the texture you like. Eddie
Re: Organisol "look" and "texture" [Re: EL5 71] #1604136
04/07/14 11:28 PM
04/07/14 11:28 PM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
Might want to try this out?
Heat up some water(I usually use water from my sink and thats hot enough)dump it into a coffee can and then put the paint can in and every few minutes I shake it up real good and do this three or four times before spraying any texture spray cans.
Re: Organisol "look" and "texture" [Re: hemi68charger] #1604137
04/08/14 11:49 AM
04/08/14 11:49 AM
Myrtle Beach, SC formerly the ...
340wedge Offline
340wedge  Offline
I am not one to bad mouth companies, but I bought that Organisol and the color was way to gray and the cans are terrible. At those prices they need to find another vendor. I also made the mistake of buying one of their steel colors, that did not work well either, and they were expensive cans of paint! I ended up finding Krylon for the steel color that was an exact match to theirs except it was about $4 a can.
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Organisol "look" and "texture" [Re: 340wedge] #1604138
04/08/14 05:02 PM
04/08/14 05:02 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Re: Organisol "look" and "texture" [Re: Triggerfish] #1604139
04/08/14 05:09 PM
04/08/14 05:09 PM
cbusters Offline
cbusters  Offline
Second that! Do it right or do it again.
Re: Organisol "look" and "texture" [Re: moparclown] #1604140
04/09/14 01:52 AM
04/09/14 01:52 AM
Thats what I've done with great success with the exception of burning my hand once. lol
Re: Organisol "look" and "texture" [Re: ] #1604141
04/24/14 07:47 PM
04/24/14 07:47 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Got around to spraying a few pieces with the Rust-Oleum Truck Bed Coating a few days ago. Stuff looks and feels awesome...just hope it holds up well.
Re: Organisol "look" and "texture" [Re: EL5 71] #1604142
04/24/14 07:48 PM
04/24/14 07:48 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
2
Re: Organisol "look" and "texture" [Re: EL5 71] #1604143
04/24/14 07:49 PM
04/24/14 07:49 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
One half of a can did this entire rear spoiler top and bottom. Legs also painted with it separately. Spray tip is AWESOME!! Never clogged once and I used up the rest of the can right to the very last drop with zero issues. Sprayed from around 24 inches away. No streaks or runs...lays down nice like it was shot from my gun and not a rattle can. It even filled a few scratches on my spoiler and made them hard to see where they were. I sprayed mine at work and put it in a bake oven at 90 degrees for one hour. Not the true factory Organisol, but definately nice for a driver type show car. Looks as if it will touch up very easily also.
Re: Organisol "look" and "texture" [Re: EL5 71] #1604144
04/26/14 05:29 AM
04/26/14 05:29 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Nice job, EL5 71!
Mo' Farts
Moderated by "tbagger".
