Re: 4 SPD bearing retainer to bell clearance.
[Re: Quicksilver440]
#1603778
04/07/14 04:20 PM
04/07/14 04:20 PM
Posts: 26,008 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you're gonna bore the BH it would be wise to check the runout as Bob suggested and factor that into the boring job. IOW, bore off-center the amount of any excessive runout.
[Re: Stanton]
#1603780
04/08/14 12:02 AM
04/08/14 12:02 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
That was my other debate... to bore it to correct or not. I can see benefits of both ways...
[Re: John_Kunkel]
#1603784
04/09/14 11:20 AM
04/09/14 11:20 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
Looking at this the original question is very confusing , is he going o turn down a retainer , which I ASSuMEd , or he is boring the bell ... or BOTH ???
[Re: JohnRR]
#1603785
04/09/14 11:24 AM
04/09/14 11:24 AM
Posts: 52,972 Romeo MI
MR_P_BODY
My opinion is that he planned on turning down the retainer
[Re: MR_P_BODY]
#1603786
04/09/14 12:35 PM
04/09/14 12:35 PM
Posts: 8,917 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I have a BB small retainer bell that needs to be opened up to accept the med size (4.8 exactly?) OD retainer
... retainer that I'm going to turn down to fit.
Confusing but most of us focused on boring the bell.
[Re: Stanton]
#1603787
04/09/14 12:45 PM
04/09/14 12:45 PM
MR_P_BODY
Myself I would most likely turn down the retainer if it doesnt run into anything.. only because its easier to throw in the lathe than centering the bell on the mill... I do have 2 auto boring heads that would do it but you still need to center the bell
[Re: Stanton]
#1603790
04/09/14 02:48 PM
04/09/14 02:48 PM
MR_P_BODY
Centering the bell in the mill would be a piece of cake with a digital readout and offsetting it would likewise be simple.
I do have the digital read out
#1603792
04/09/14 04:35 PM
04/09/14 04:35 PM
MR_P_BODY
Thanks for all the input...I will bore the BH to correct runout then.
This is my first 4 SPD...so its all new to me.
This was his last post so I see what he is doing now which is no problem except time.. degree the bell then cut it... but maybe like Bob said the drain and a few minor things might have been a issue if turning the retainer... its only been about 25 years since I even looked at one
