date coded engins and cars #160325
12/02/08 09:21 PM
12/02/08 09:21 PM
3
340dart4spd Offline OP
Parts Problem
Parts Problem
3
I need to know what is the correct date code for my car
https://board.moparts.org/ubbthreads/show...e=0#Post4853520
Re: date coded engins and cars [Re: 340dart4spd ] #160326
12/02/08 09:27 PM
12/02/08 09:27 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Same question as Scott "Which Engine?"
MikeR
Re: date coded engins and cars [Re: A12] #160327
12/02/08 09:28 PM
12/02/08 09:28 PM
3
Parts Problem
Parts Problem
3
440
Re: date coded engins and cars [Re: A12] #160328
12/02/08 09:29 PM
12/02/08 09:29 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I guess another question would be which assembly plant for the car or does that matter?
Re: date coded engins and cars [Re: A12] #160329
12/02/08 09:32 PM
12/02/08 09:32 PM
3
Parts Problem
Parts Problem
3
lynch road 70 coronet r/t
I have a 0A hp block
and a OB which is not correct for it
Re: date coded engins and cars [Re: 340dart4spd ] #160330
12/02/08 10:05 PM
12/02/08 10:05 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
This '69 440 Lynch Road built RR had a cast date of 5-1-69, an Engine Assembly Date (EAD) of 5-21 and a VIN 9A2706XX which might make it a last week of May/first week of June car assembly?
Another '69 "B" plant (Hmtrk) 440 has a 11-16-68 cast date with a 12-18 (or 2-18) EAD and a VIN 9B301XXX, maybe someone can chime in with an approximate car assembly date?
Another engine I have has a 2-27-69 cast date with a 3-28 EAD but no VIN (over the counter "crate engine" )
It seems to be a 4+ week difference from cast date to Engine Assembly Date for the three 440 engines I have record of and maybe 2+ weeks from EAD to car assembly for two of them. I have seen blocks cast as much as 3-4 months from the EAD but not as many as the 4+ weeks cast to EAD and 2+ weeks into a car. That is my "ballpark" take but I'm sure there are many more with their own experiences to share. The A12 resto group was working on a K-frame date code as being a telltale on an approximate car assembly period but that's another discussion IMO.
MikeR
Re: date coded engins and cars [Re: 340dart4spd ] #160331
12/02/08 10:06 PM
12/02/08 10:06 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Please don't post the same question in multiple forums, or multiple times. Thanks.
Earning every penny of that moderator paycheck.
DBAP
