Early Hemi vin code ? #1601882
04/01/14 10:20 PM
04/01/14 10:20 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
I have a early hemi vin D44- 45725 .. What can be told by this number..
Re: Early Hemi vin code ? [Re: robnbird] #1601883
04/01/14 11:00 PM
04/01/14 11:00 PM
moparx Offline
moparx  Offline
D44 represents 1953 dodge 241ci. block # began with 10001 if I recall correctly.
Re: Early Hemi vin code ? [Re: moparx] #1601884
04/01/14 11:08 PM
04/01/14 11:08 PM
NW IL
Biggie Offline
Biggie  Offline
NW IL
2bl with 140hp
http://www.hothemiheads.com/hemi_info/hemi_engine_id.html
"Think of all the Ford owners who will someday want an automobile." John Dodge
57 dodge sierra wagon
03 chrysler 300m
10 dodge charger
Re: Early Hemi vin code ? [Re: Biggie] #1601885
04/01/14 11:43 PM
04/01/14 11:43 PM
moparx Offline
moparx  Offline
trwaters is our resident expert on early hemis. perhaps he can add something to this ? what are your plans for this engine ? I have one of these that has been disassembled for over 30 years stashed on the rack in the garage, but really never decided what to use it in.........
Re: Early Hemi vin code ? [Re: moparx] #1601886
04/02/14 12:32 AM
04/02/14 12:32 AM
tn
robnbird Offline OP
robnbird  Offline OP
tn
I am not sure what to do with it..
Re: Early Hemi vin code ? [Re: Biggie] #1601887
04/02/14 12:35 AM
04/02/14 12:35 AM
tn
robnbird Offline OP
robnbird  Offline OP
tn
2bl with 140hp
are the heads the same for a 241 - 331 - 354 ???
Re: Early Hemi vin code ? [Re: robnbird] #1601888
04/02/14 12:44 AM
04/02/14 12:44 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Nope, 241 270 are Dodge
331-354-392 are Chrysler
Virtually nothing of usefulness swaps.
Then there are the Desoto Hemis, they don;t swap much either. Plus some of the Chrysler Hemi stuff doesn't swap within Chrysler. I have no idea what Chrysler was thinking making 47 different engines that swapped nothing between them back then.
Don't be the exception.
Re: Early Hemi vin code ? [Re: Supercuda] #1601889
04/02/14 04:01 PM
04/02/14 04:01 PM
dogdays Offline
dogdays  Offline
Dodge, DeSoto and Chrysler each had their own bore spacing. To complicate matters, each division had two deck heights.
The Dodge 241 is really cute, although it's half the displacement of a stroker big-block. It looks like it'd fit in a Model A or other early '30s car without any sweat.
R.
Re: Early Hemi vin code ? [Re: dogdays] #1601890
04/02/14 04:35 PM
04/02/14 04:35 PM
NH
3
36dodge Offline
36dodge  Offline
NH
Are these considered the The red rams 240??
Re: Early Hemi vin code ? [Re: 36dodge] #1601891
04/03/14 01:31 PM
04/03/14 01:31 PM
dogdays Offline
dogdays  Offline
The 241 had valve covers that said Red Ram across the top with a ram between the two words, then DODGE across the bottom below the spark plugs.
R.
Do a websearch, there are plenty of photos out there.
Re: Early Hemi vin code ? [Re: dogdays] #1601892
04/05/14 03:26 PM
04/05/14 03:26 PM
Colorado
CaptainGTX Offline
CaptainGTX  Offline
Colorado
241 cu in Red Ram rated at 140 hp. Here's the original engine in my unrestored 53 Dodge Coronet convertible (picture doesn't want to attach - will try later). Not a powerhouse, but it would outrun almost everything produced back then. Set numerous track speed records & won the Mobilgas economy runs as well.
Re: Early Hemi vin code ? [Re: Supercuda] #1601893
04/06/14 05:53 AM
04/06/14 05:53 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
all the non interchangeability is what lead to the end of the early hemi motors, not all 241 had the red ram dodge logos on the valve covers,,they are highly sought after,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Early Hemi vin code ? [Re: fstfish66] #1601894
04/07/14 02:56 PM
04/07/14 02:56 PM
dogdays Offline
dogdays  Offline
At the same time GM had different V8s for each of their brands, no interchangeability there either. That's how it was in the old days.
Also, the more expensive the car, the more powerful the engine (generally). In the Chrysler world, from top to bottom: Chrysler, DeSoto, Dodge, Plymouth. So it stands to reason that the engines got smaller as one moved down the list.
My Grandpa sold DeSotos and Plymouths. If he'd been in a ritzier neighborhood he'd have been selling Chryslers and Dodges.
R.
Re: Early Hemi vin code ? [Re: dogdays] #1601895
04/10/14 04:10 AM
04/10/14 04:10 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
if you read on the early hemi motors you will see thaty chrysler says the early hemi program was stopped due to expense from all brands being totally different
2015 cherokee
2013 R/T classic
Re: Early Hemi vin code ? [Re: fstfish66] #1601896
04/15/14 10:34 PM
04/15/14 10:34 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
241 heads are all by themselves.
