Re: Converters, Coan or ATI?
[Re: Sport440]
#1599824
03/28/14 07:37 PM
03/28/14 07:37 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
Love the ATI behind my small blk
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: Chris2581]
#1599829
03/28/14 11:15 PM
03/28/14 11:15 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: Chris2581]
#1599832
03/29/14 01:24 AM
03/29/14 01:24 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Turbo Action....
www.turboaction.com
This is what I run... been a couple of real good convs and TA conv have been what MP sells for YEARS... he has been a mopar guy for years
[Re: 68roadrunner]
#1599836
03/29/14 12:49 PM
03/29/14 12:49 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Sounds like whatever you had worked well. Why not have whoever built it make you another
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: wyoming]
#1599837
03/29/14 01:01 PM
03/29/14 01:01 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
All of those can be good choices, myself I have a Dynamic, all the guys mentioned build good convertors, one of the main keys is communication in both directions.
I agree with that. I use Dynamic and Turbo Action and they have been great as are any of the mentioned converters in this post. We should make a converter list or something like that and put it in the tech area as this question gets asked about twice a week so maybe it would be a good idea to make a list up of the good converter companies. Ron
[Re: B3422W5]
#1599839
03/29/14 01:27 PM
03/29/14 01:27 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
The converter is five years old and has maybe 50 1/8 mile passes and I'd guess less than 3000 street miles on it. The 60' and mph started going away two years go, I've lost .3-.4 in the 1/8.
At first I thought it was a transmission problem. At cruise in high gear if it was matted the rpms would jump to 6000 then pull from there. So I built a new 727 over the winter, everything new. Put it in and the same thing as the old one on the street. Pulled the new trans and let a local shop take it apart and find where I had screwed up. I picked it up yesterday, they didn't find anything wrong.
So I don't want to spend the money to have this one freshened up and have the same problem start in three years. I'll spend the money on a good one this time.
