Pinion angle help #1598412
03/25/14 09:26 PM
03/25/14 09:26 PM
Nanuet, NY
3
383BeepBeep Offline OP
Nanuet, NY
There is way to much information on pinion angle out there, that I am confused. I bought an angle finder and took measurements. The confusion comes in when doing the math. If the pinion is facing down does that angle get a + or a -? So I drew a picture. Could someone please dumb down the whole pinion angle equation? Thanks
1969 Plymouth Roadrunner - 383- 4 Speed - Dana 60 4:10
Re: Pinion angle help [Re: 383BeepBeep] #1598413
03/25/14 09:33 PM
03/25/14 09:33 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
,though not much help
Re: Pinion angle help [Re: 383BeepBeep] #1598414
03/25/14 10:07 PM
03/25/14 10:07 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I'll try. In your drawing you are 6.5* nose down from parallel.
The easiest thing to do from your drawing is to rotate the tranny angle up to 0 to parallel from your 2* down. For explanation sake.
Its now easy to see that your pinion angle is now 4.5 nose down from parallel.
But your tranny angle is down 2* down, so being down 2* your pinion angle is 6.5* down. At 0 it would be 4.5* down. If the tranny was 2* up you would have a 2.5* down pinion angle.
Your driveshaft angle only comes into play if its to extreme, meaning if the axel is Much lower then the tranny centerline.
Correct pinion angle is so the U-Joints work together well both under power and on decell.
I am sure, this is still not clear to many, it never is.
Re: Pinion angle help [Re: Sport440] #1598415
03/25/14 10:10 PM
03/25/14 10:10 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
This is some of the easiest info I found on it. The first 2 paragraphs in the orange tell alot. Hope it helps yopu some. Ron
http://www.moparts.org/Tech/Archive/axle/8.html
Re: Pinion angle help [Re: 383BeepBeep] #1598416
03/25/14 10:25 PM
03/25/14 10:25 PM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
If I am interpreting correctly your diff is pointing 4.5 degrees downward toward the u-joint. You sum that angle and the driveshaft angle (assuming your drawing representation on the driveshaft sloping down to the rear).
Looks like you are 8 degrees nose down at the rear joint and 1.5 at the front. Since the slope of the driveshaft and transmission are the same direction you subtract.
Per the Mopar Chassis Manual, 9th Ed. Chapter 6.
Front U-joint should be 2.5 degrees or less, but not zero.
Rear U-joint
Standard Leaf: 5-10 degrees nose down, 5-7 preferred
Leaf Link: 3-5 degrees nose down
4-Bar (double pivot) link: 2 degrees nose down
Ladder (single pivot) link: 1 degree nose down
Oval Track Leaf Spring: 4-5 degrees nose down
So, in other words, if you have a leaf car you should be OK, but you could be better if you took 1-2 degrees out of the diff. If you do not have vibration cruising or under deceleration, then you are likely OK where you are.
-Michael
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: Pinion angle help [Re: 383man] #1598417
03/25/14 10:32 PM
03/25/14 10:32 PM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Drawings and table are straight from the Mopar Chassis manual, if your's looks like figure 9-12(A) then my above statements are correct.
-Michael
Re: Pinion angle help [Re: 383BeepBeep] #1598418
03/25/14 11:13 PM
03/25/14 11:13 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
BEEP, Since you can draw on the pute.
Can you Fix your drawing to show the different angles between the diff and the tranny.
Alls you have now is a Single angle shown between the tranny and diff that really doesnt show anything but that angle.
If you can, Show a flat horizontal angle. Then add in your Trannies 2* down and your Diffs 4.5* down angles in relationship to that.
I can do this,
Horizontal _________________________________
As per your info, you are 6.5* nose down as is..
Re: Pinion angle help [Re: 68cuda440] #1598419
03/26/14 12:33 AM
03/26/14 12:33 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Thats a wrong interpretation, The diff is pointing down 4.5 degrees from parallel measured by a angle finder thats based off of a parallel plane.
Re: Pinion angle help [Re: 383BeepBeep] #1598420
03/26/14 12:48 AM
03/26/14 12:48 AM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
It comes down to working angles. The front working angle (1.5º) is in the ballpark. The rear is almost (8º) assuming your I am reading the drawing correctly. You want to try to keep it at or under 3º of working angle. Most likely need to get some different shims for the leafs.
Example: take your 4.5º of pinion and go to 1º to 1½º. That to me should look better.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: Pinion angle help [Re: Sport440] #1598421
03/27/14 12:12 AM
03/27/14 12:12 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
What I mean is the nose is lower than the axle tube, correct? Parallel to the ground correct?
Re: Pinion angle help [Re: 68cuda440] #1598422
03/27/14 10:48 AM
03/27/14 10:48 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
A picture is worth a thousand words as they say.....
http://www.youtube.com/watch?v=gmV4qwLfOMY
Re: Pinion angle help [Re: brads70] #1598423
04/08/14 11:18 PM
04/08/14 11:18 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Not sure I want to do this.
But IMO, This VID shows why you Dont just set the pinion angle off of the "Pinion and Drive shaft" measurement.
Its the "Tranny and Pinion" angle thats most relevant.
With the drive shafts angle coming coming in last. You dont want it to be to steep, witch isnt the case on our race cars.
Every time a Pinion angle debate comes up, Id like to see this vid pop up. Its not the best, I would of preferred that the driven motor appear to be the tranny output shaft.
BTTT.
Just thinking a duplicate of this thread or vid would be nice in the Unlawfl race section.
Re: Pinion angle help [Re: Sport440] #1598424
04/17/14 03:20 PM
04/17/14 03:20 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Just my o-pinion (pun intended)
I just dealt with this same issue on my build. I found that once I got it (middle drawing) into my head, it was very easy to understand.
Study and understand the middle picture. It clearly shows a 0.0* relationship pinion to transmission.
What I found confusing was that I kept seeing transmission as a Horizontal line. Forget Horizontal, its just the "drawn" engine/transmission center line.
If you lift the rear of your car by the rear axle/wheels till the engine/transmission are level, then it makes it easier to understand pinion down/up (IMO).
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
