2002 4.7 trans #1598383
03/25/14 07:19 PM
03/25/14 07:19 PM
nc
E
earthmover Offline OP
E
nc
ok guys I have a few choices here buy a new reman trans or get a used with a 1yr on it..never had to do much to this truck so is this trans something that I can do in a few hours in my shop..have never really been under it and looked and im out of town working now..hate to have it sitting in the shop cause I don't have much home time when there..
Re: 2002 4.7 trans [Re: earthmover] #1598384
03/25/14 08:19 PM
03/25/14 08:19 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You are leaving out a couple of factors that may influence your decision. The current mileage and general condition of your truck, The cost of the reman VS the used unit, and condition and miles on the used unit. The 45RFE trans in my findings is a pretty reliable unit and I would have no problem putting in a low-mile used unit calling it good. That is, ASSuming you have an automatic trans. What happened to your trans?
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2002 4.7 trans [Re: 71yelladustr] #1598385
03/25/14 08:48 PM
03/25/14 08:48 PM
nc
E
E
nc
sorry my truck is a 2002 4.7 and I have 203xxx miles on it and haven't really had any problems out the truck but this trans..
now the problems started when they had a recall to put a switch and adjust something on the trans..it has a grinding sound when you put it in gear and when its in rev it will start to pull then stop then start again..i use not drive the truck much as im in my work truck most of my days..the last 2 yrs I have done a lot of driving in and out of town to jobs..im 2 hrs away from home now working...and sometimes I have to go back home 2/3 times a week for tools or pick up parts for my work truck I cant find out here..(dump truck)...im not sure of the miles on the trans as I haven't talk to the company yet just got a price on it..and was told it has a 1 yr with it...for 600.00 ask a shop to rebuild the 1 in the truck was told 2000.00 with 1 yr...thought about getting a cummins but don't want any payments lol I have tried changing the fluids every few months and filters but it still does it..some times it don't do it at all..now its got to where it will jump up and down in rpms going down the interstate and I don t want to be on the road coming or going home broke down if I can help it...any advice or help would be great...also when I start the truck up some times and put it in gear it want even move for a few seconds like the fluid has to be picked up or something...just hope I never have to leave in a hurry......
Re: 2002 4.7 trans [Re: earthmover] #1598386
03/26/14 12:52 AM
03/26/14 12:52 AM
Missouri U.S.A.
Missouri U.S.A.
Even though the filters have been changed, still sounds like the main filter may not be seated all of the way into the front pump causing a loss of prime. The seal in the pump where the filter connects can also come loose causing the same problem. This is very common. The filters are also know to crack down the side of the filter causing a similar issue. There is a TSB on this beleived to be caused by the spin-on cooler filter from MOPAR with the letters "AB" at the end of the part number on the outside of the filter. Might wanna drop the pan and have a look before doing anything drastic.
10.02@134
Re: 2002 4.7 trans [Re: 71yelladustr] #1598387
03/26/14 10:42 AM
03/26/14 10:42 AM
nc
E
E
nc
il will take a look and see ..its worth that but I have changed the fuild and filters in this thing about 8 times and always the same end results... this time I will look at the mounting points and make sure cause I never have thought of it cracking or losing the seal ..and most the filters have a plastic pc that it use to mount on with as well..thanks
Re: 2002 4.7 trans [Re: earthmover] #1598388
03/26/14 01:32 PM
03/26/14 01:32 PM
dogdays Offline
dogdays  Offline
Any chance this could be the TPS issue discussed in another thread? Might be worth a few dollars to find out.
r.
Re: 2002 4.7 trans [Re: dogdays] #1598389
03/26/14 09:09 PM
03/26/14 09:09 PM
Missouri U.S.A.
Missouri U.S.A.
The TPS wont cause the delayed engagement problem he has.
10.02@134
Re: 2002 4.7 trans [Re: 71yelladustr] #1598390
04/08/14 09:37 PM
04/08/14 09:37 PM
nc
E
E
nc
is this something that can be rebuild in a weekend in the shop at home
