1971 Challenger R/T stripe positioning
#159822
12/01/08 08:38 PM
12/01/08 08:38 PM
Posts: 1,018 Missouri
MOBodyman
Missouri
I'm getting ready to install the side stripes on a '71 R/T and was wondering how far up from the bodyline they go. I plan to use the door handle opening as a reference point. Does the stripe go to the bottom of the opening or is it level with the bottom edge of the handle itself? A close-up pic or some dimensions would be helpful. TIA, Dallas
2012 Rallye Redline Challenger, 1st new car! 2010 Ram 1500 4wd HEMI-hauler 2014 Dodge Dart-gas saver 4 projects and a bunch of parts cars, losing interest since buying the Challenger lol 1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: 1971 Cahllenger R/T stripe positioning
[Re: MOBodyman]
#159823
12/01/08 09:03 PM
12/01/08 09:03 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
If you bought good quality stripes, they should be cut out for the handle making them fit only one way. There should be roughly 3/16 to a 1/4 gap around the handle. The bottom of the stripes run parallel to the mid-body line.
CHECK OUT MY NEW WEB SITE !
Re: 1971 Challenger R/T stripe positioning
[Re: anlauto]
#159824
12/01/08 09:22 PM
12/01/08 09:22 PM
MOBodyman
Missouri
I didn't buy these, they were provided by the owner. They are cut out for the handle but not enough for a gap around the outside like you described. These have enough material to lap into the handle opening. Does the bottom of the stripe line up with the bottom edge of the door handle? Thanks for your reply, Dallas
[Re: MuscleMopars]
#159826
12/03/08 02:05 AM
12/03/08 02:05 AM
MOBodyman
Missouri
Thanks for the replies. I put them on today. Dallas
