rpm window switch #1597956
03/24/14 06:38 PM
03/24/14 06:38 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
if I put a piece of wire in where the chip goes will that turn it on. I want to check my nitrous circuit without starting it.
Re: rpm window switch [Re: plycuda] #1597957
03/24/14 06:49 PM
03/24/14 06:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It should.. the chip is basically just a switch based
on a resistance to turn it on
EDIT
with a VOM see if there is a small voltage on one
of the pins where the chip goes in... the other will
be going to what ever it turns on and should be
going to ground through the item being turned on
Re: rpm window switch [Re: MR_P_BODY] #1597958
03/24/14 07:06 PM
03/24/14 07:06 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
thks I'll try it
