3.54 DANA 60 date & BOM decode? #1597668
03/24/14 03:27 AM
03/24/14 03:27 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
What is the difference between a "POWR-LOK" vs. "TRAC-LOK"? What's the date code "9 16 0C1"?
This chart shows the same 3.54:1 DANA 60 (& axle lengths) for '70-'72 b-bodies?
That's not correct, is it?
Re: 3.54 DANA 60 date & BOM decode? [Re: 6bblgt] #1597669
03/24/14 03:38 AM
03/24/14 03:38 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
That chart is incorrect.
'66-'69 Dana 60 rears used (heavy duty 4 pinion) 23 spline Power-Lock sure-grips.
'70 Dana 60 rears used (heavy duty 4 pinion) 35 spline Power-Lock sure-grips.
'71-72 Dana 60 rears used (light duty 2 pinion) 35 spline Track-Lock sure-grips.
The date is Sept 16, 1970
Re: 3.54 DANA 60 date & BOM decode? [Re: DoctorDiff] #1597670
03/24/14 03:57 AM
03/24/14 03:57 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
Thanks!! this '72 b-body (12/8/71 C08-SPD) sure seems to have many left over parts - Chrysler must have been cleaning up the parts bins.
Re: 3.54 DANA 60 date & BOM decode? [Re: 6bblgt] #1597671
03/24/14 04:25 AM
03/24/14 04:25 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You should find another date stamped on the tube close to the one you posted.
As far as I know, one date signifies when the housing was built. The other specifies the assembly date.
