1974 charger lower ball joints #1597509
03/23/14 06:15 PM
03/23/14 06:15 PM
Albuquerque, new mexico
moparvinson Offline OP
I am building a 1974 charger for my son and have all new ball joints. can you change the lowers with a ball joint press that you can rent from autozone or does rhe lower control arm have to come out? Thanks.
Re: 1974 charger lower ball joints [Re: moparvinson] #1597510
03/24/14 04:48 AM
03/24/14 04:48 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
IIRC they unbolt like all other LBJs?
I am truckless..
Re: 1974 charger lower ball joints [Re: 340SHORTY] #1597511
03/24/14 08:02 AM
03/24/14 08:02 AM
Bellevue,Mich.
Dodge33 Offline
Dodge33  Offline
Bellevue,Mich.
hello, been awhile but if i am thinking right,
you can use a press and do them on the car.
Re: 1974 charger lower ball joints [Re: Dodge33] #1597512
03/24/14 03:22 PM
03/24/14 03:22 PM
Thanks, I will give it a shot. I know 1974 went to press in lowers but wasnt sure if control arm had to go in a big press or not.
Re: 1974 charger lower ball joints [Re: moparvinson] #1597513
03/24/14 10:44 PM
03/24/14 10:44 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Take a good look at it before you press it out...Some of the 74 LCAs had screw in lower balljoints...I remember one member on here was after he ruined one...
Re: 1974 charger lower ball joints [Re: screamindriver] #1597514
03/25/14 02:02 AM
03/25/14 02:02 AM
Thanks, I already checked them. upper has the kinda square shape for the special socket, lower is perfectly round.
