Inside Rear Window trim screws? #1596558
03/22/14 10:36 AM
03/22/14 10:36 AM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
Anyone know what type of screws that are used for the corners of the inside rear window trim on a 69 Charger?
Mine are missing.
A pic would be helpful, or if you know where to buy.
TIA
Re: Inside Rear Window trim screws? [Re: MONC] #1596559
03/22/14 11:33 AM
03/22/14 11:33 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
#8 pan head chrome screw... not 100% sure but I think about 1" long
Re: Inside Rear Window trim screws? [Re: gtx6970] #1596560
03/22/14 11:37 AM
03/22/14 11:37 AM
MONC Offline OP
MONC  Offline OP
Thanks, I was going to ask how long.
Re: Inside Rear Window trim screws? [Re: MONC] #1596561
03/22/14 11:59 AM
03/22/14 11:59 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I don't know about those screws specifically, but most interior screws are unusual in that they have heads like the next smaller size screw. That makes it almost impossible to get any interior screws at a hardware store.
Master, again and still
Re: Inside Rear Window trim screws? [Re: DaveRS23] #1596562
03/22/14 02:36 PM
03/22/14 02:36 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
They're called 'Jackson head' screws.....I'd bet Fastenal could match them up.
Re: Inside Rear Window trim screws? [Re: Powerflow] #1596563
03/22/14 09:38 PM
03/22/14 09:38 PM
MONC Offline OP
MONC  Offline OP
Like these?
Re: Inside Rear Window trim screws? [Re: MONC] #1596564
03/22/14 09:53 PM
03/22/14 09:53 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Like these?
Looks about right. When you set a hardware store screw next to an interior screw, the smaller head on the interior screw is obvious. The hardware store screws just won't sit flush with the trim when screwed down.
And of course, the interior screws are chromed.
