1957 dodge truck frame transplant?
#1596432
03/22/14 01:23 AM
03/22/14 01:23 AM
Posts: 1,630 North Central Florida
eightlitermopar
My dad has a very slow project ongoing: 1957 Dodge D100 The frame is solid, but we have run into a problem. We have a 440 and automatic transmission in place, but I cannot see how we can make the steering work. The motor is right in the way and there is no way around it unless we completely redneck it. We have not touched the cab and we would prefer not to cut it up if possible.
Here is my first question: The frame is original with front leaf springs etc….. Would I be better off at this point with a new frame to put the cab on? This way the 440 and the steering would work?
Here is the follow up question: If a new frame swap would be easier….what trucks would work the best?
I know of a 1982 dodge truck, long bed, 2wd. Or….should I go with the Dakota frame instead?
We are at a crossroads where we could go many directions at this point.
Eightlitermopar
Attached are the pictures of the truck as it sits right now....
Mopar or no car
Re: 1957 dodge truck frame transplant?
[Re: savoy64]
#1596438
03/22/14 12:23 PM
03/22/14 12:23 PM
eightlitermopar
Hmmm....good thoughts here. I could try the u-joint trick and see if that could work. That seems like it would be the least invasive....for now anyway. Since I have never set up steering like this....does anyone have a site or resource they recommend for something like that (u-joints for steering)? I am also keeping my eyes peeled for a cheap early Dakota if this plan does not work. eightlitermopar
Mopar or no car
[Re: savoy64]
#1596440
03/23/14 12:47 AM
03/23/14 12:47 AM
Posts: 586 UP
finn
UP
mustang II are only barely adequate----mustang guys upgrade to granada components---hot rod guys know that their big block setups have too much power for the MII brakes---early dakota clip is the way to go.....
I'm not sure where you are getting your information from.. The MII kits all seem to use an 11' rotor, which is pretty close to the 11.3 of the Dakota. The Granada spindles and brakes are a popular swap into 50's Fords using the original suspension, but nobody in their right mind would use a Granada suspension, which is like the early (pre-MustangII) with the unibody shock tower high spring mount. It would never work.
The advantage of the MII is that these kits have been out there for probably 25 years now and there are many reputable companies offering well thought out kits. They don't require butchering your frame and jerry rigging a front core support like a clip does The MII kits are proven and popular.
Another swap that is becoming very popular is the Jaguar suspension. It is a bolt on unit on the late Jag and is supposedly pretty available and reasonable.
The Crown Vic (03 up) is another unit that is popular on the 50's Ford ickups, but seems to be a little wide, so you have to use the Crown Vic wheels.
People do use the Dakota clip, but it doesn't seem popular.
Clipping was a 70's and 80's thing. Latest builds seem to avoid it.
[Re: 76dodgeboy]
#1596442
03/31/14 07:04 AM
03/31/14 07:04 AM
eightlitermopar
Thanks again guys...I think we are going to figure out steering first before we start transplanting.... I honestly didn't know how easy or complicated it would be. I will let you know how it turns out!
Mopar or no car
