91 body bushings #1595632
03/20/14 12:26 AM
03/20/14 12:26 AM
Albion NY
Haibach Boys Offline OP
Albion NY
Cant seem to find them listed for a 91 w150. Energysuspension has them for 72-85. Will these work? I did see Daystar has a "$uperkit" for Mucho $$$ listed 69-93? Any input? I just want to get my cab bolted on and painted.
Re: 91 body bushings [Re: Haibach Boys] #1595633
03/20/14 10:42 AM
03/20/14 10:42 AM
scratchnfotraction Offline
they will use the same bushings as what you see listed.
I just did this with the 85 stepside... I swaped a 91 cab on.
whats is different is the bolts/nuts used.
you do use a few of the old washer with some new ones supplied.
the 85 bolts/nuts(bolts down thru floor-nuts on bottom have a shoulder to butt up on washers and the 91 has a sleeve the washers butt up to with the nut capturd in the floor area. bolts go up from bottom.
on the core support the 85 used a short sleeve in the bushing and the kit comes with 2 sizes so you atch those up.
I can go back and look to see what poly bushing kit part # I used.
they are vage on discription but they do fit 72-93.. just use correct bolt for the yr cab.
Re: 91 body bushings [Re: scratchnfotraction] #1595634
03/20/14 11:07 AM
03/20/14 11:07 AM
Albion NY
Albion NY
terrific, i assumed that it would interchange to some degree. ill order up the energy suspension ones.
Re: 91 body bushings [Re: Haibach Boys] #1595635
03/20/14 11:32 AM
03/20/14 11:32 AM
yea, thats the ones I used.
Re: 91 body bushings [Re: scratchnfotraction] #1595636
03/20/14 11:37 AM
03/20/14 11:37 AM
Re: 91 body bushings [Re: scratchnfotraction] #1595637
03/20/14 01:14 PM
03/20/14 01:14 PM
Albion NY
Albion NY
i can hear my wife now... "what did you buy now?!" "stop putting money in that P.o.S."
Re: 91 body bushings [Re: Haibach Boys] #1595638
03/20/14 05:38 PM
03/20/14 05:38 PM
I tell mine it is a quarterly investment for no monthy payments.
